Aftermarket Lug Nuts
Old Feb 15, 2009 | 01:47 PM
Triple6's Avatar
Default Aftermarket Lug Nuts
I know this has probably already been covered, but I stink at searching. Does anyone make aftermarket lug nuts that fit the factory T/C 17" wheels? Can't seem to find any that will fit down in the counterbore they all seem to have the taper instead.
Old Feb 16, 2009 | 05:48 PM
10PieceNuggets's Avatar
It is not recommended to use aftermarket lug nuts on the stock rims.
Old Feb 16, 2009 | 05:55 PM
ack154's Avatar
Default Re: Aftermarket Lug Nuts
I might have an extra set of OEM lugs at home if you need some. I can't check until after 5, but I'm sure we could work out a deal if you need them.
Old Feb 16, 2009 | 06:34 PM
Triple6's Avatar
I know I don't want to use the aftermarket type that has the cone that buts up to the wheel. I was just hopeing that someone made a type that would work with factory wheels. I have several sets, just none that works like factory (other than the ones already on the wheels).
Old Feb 16, 2009 | 08:15 PM
highvoltage1's Avatar
Why do you want aftermarket lugs?
Old Feb 17, 2009 | 12:04 AM
Triple6's Avatar
Cuss I like Red and I'm not into spray painting something that will come off everytime I rotate the tires. Why do you ask?
Old Feb 17, 2009 | 12:16 AM
Oh ok. I am sure there are some that will work. Let me see if I can get you alink to a bunch of lugs and see if they will work.
Old Feb 17, 2009 | 12:18 AM
Originally Posted by ScionJim23
Here's a good site to look at. Lots of good ones....Be prepared to pay. Also, buy locking lugs.
http://www.evasivemotorsports.com/me...tegory_Code=L1
here
Old Feb 17, 2009 | 12:19 AM
SengTC3's Avatar
just make sure the lugs are flat and not conical... and that they are 1.50 and not 1.25. I have 4 sets of lugs right now... standard, splines, standard lookings ones with conical ends, and bright purple blox lugs... I know speedelement is having a say on ray extendeds but.... there 1.25 =/
Old Feb 17, 2009 | 12:22 AM
Aroddalobster's Avatar
last time i checked, evasive sold no oem seated lugs.
Old Feb 17, 2009 | 12:37 AM
Triple6's Avatar
Checked the site, didn't see any that wasn't conical. Makes me wish I still had access to the old machine shop I worked at.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gyrotech
Scion tC 2G Aero & Exterior
Oct 4, 2015 11:03 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vintage42
Sep 12, 2015 12:59 AM
antayala
Sep 4, 2015 05:12 PM
