DIY REQEUST -- rotors & brake lines
Ive been searching for like an hour plus now here and other sites i even resorted to google....i checked wilwoods web site and even tried to go to like brembo.com which bumps me to tires.om...and nothing...
can anyone pelase point in the direction of a diy for rotors and brake lines including trque specs and nut bolt sizes? Thanks in advance for taking the time to waste some time on me.
holla
j
holla
j
The rotors are free floating - they're actually held in place by the calipers. Remove the 2 14mm bolts holding on the caliper and pull it off. You may need to hit the CENTER part of the rotor (by the wheel studs) a few times with a rubber mallet to break the rust and other junk off. You'll see the rotor will start to hang loosely then you can pull it off.
Brake lines are tougher - you should get a brake line wrench tool from an auto parts store. It's basically a wrench that will fit the brake line nuts and won't strip them. If you change your brake lines you will need to bleed your brakes. You'll need a brake bleeder wrench so you don't mangle your bleeder valves.
good idea about the different wrenches to prevent damage, but totally un-necessary unless you ham-fisted it.
on second thought, he does need a DIY for it, so better take the precautions.
mine were a piece of cake. one bolt behind the caliper to flip it up to take out the pads, a 2nd MUCH longer one to take out the caliper, then hammer off the rotor, unbolt the lines, and bleed the brakes with a friend and an open-ended wrench.
Done in under 1hr.
Done in under 1hr.
thanks for all the tips guys....thanks i do appreciate it. My friend who is a certified tech is gonna be there...to walk me threw the process since i want to get my hands dirty and learn how to do stuff like this...
TotalChaos
Apr 7, 2015 09:02 PM
kdanie
9
Jul 12, 2005 01:12 AM
kdanie
Jan 29, 2004 03:26 AM
