enkei rpf1 17x7.5 +48 5x100 fit on a tc?
i am about to get a set of rpf1 from this guy who has it on his WRX. I read it on the WRX forums that wrx wheels won't' fit on tc vice versa. Something being the bore size too big on wrx.
should i go for it?
should i go for it?
Since the wheels have a 5x100 bolt pattern, they can used on a tC1. As stated above you will have to purchase the proper sized hubcentric rings for a proper install. Also, keep in mind that the with a higher positive offset, the more tucked the wheel is going to be. Since the wheels you're getting has a +48 offset on a wheel that's about .5 inch wider than the oem wheel, you might retain the OEM wheel-tucked look (OEM 17' wheel is 17x7, +45 offset). If you want the wheels sitting flush with the fender, you might want to add maybe a 15mm spacer.
are you saying im going to have a "slameed" look?
i got hubcentric rings off ebay for 5 bucks for my rpf1s, new.
if the hub size on the tc is the same as the xb2,
http://www.ebay.com/itm/380319030482...9#ht_509wt_963
you need the 60.1-73mm rings
Onestepahead85
Apr 28, 2015 07:05 PM
SubrinaIsMyCar
Mar 8, 2015 07:53 AM
