finally got 15mm spacers installed..!
well.. finally got the H&R 15mm spacers installed on the rear... what a difference in looks..... i can now stand to look at the car from the front angles... and the install of the wheels studs was actually easier than i thought... i was prepared to spend a weekend doing it.. but it only took about 1 hour in total....
just alittle backround.. i have motegi FF7 19x7.5 wheel and they have a 45mm offset.. which i guess is/was fine, there is no danger of rubbing and i guess it looked ok without the spacer.. i think the 215 35's had alittle to do with how i felt they looked .. just had way too much gap.. and i was actually going to go with a 225 35 for my next set of tires to hopefully eat up alittle of that gap..... (it is dropped on trd springs aswell)...
im glad i have the TRD springs and not another brand... the spacers changed the offset to 30mm.. which puts the lip of the wheels just shy of the edge of the fender.. and if the car had been any lower i think even with the 215's it may just had rub'd.. but with the TRD spings ther is plenty of space left...... im still contemplating 225's.. but now that i have have the spacers in... ill have to think about it....
i sort of liked the wider stance out back.. i was asked if i was going to do the same for the fronts... but the way it looks i think im going to keep it just the rear..
i hate posting pics because you never get to show what it really looks like.. but anyways.. here is one i just took this morning.. again.. the pic doe snot really do it justice.. oh well..
Does look better... I've wanted to get some spaces for a while, but they're expensive. And I have other things to blow my money on.
But I wanted to do 20mm in the rear and 15 up front. Seems like it keeps it more even.
yeah... they were on the expensive side.. $100.... i have a set of H&R 5mm spacers but never used them because they do not have the ring to keep the wheels hub centric... with my wheels.. 15 would be the biggest i could go out back and keep the wheels under the fender..
how do the 215's look on the ff7's, are they stretched? i just bought 19" ff7's and im looking for tires now. i was planning on sticking with the 215 but i didnt know how stretched the tire was.
can you post anymore pics? please
thanks
thanks
thanks
thanks
Yeah.. they are slightly stretched... im going to take a pic from the rear and post it.. ill try to get it so you can see the tire aswell...
OK.. here is a shot from the rear... i tried to get a shot so danman4x could see the tires on the rim.. aswell.. as show where the wheel sits now.. Dan.. if you can't see the tire.. let me know.. i can probably lighten the pic up alittle.. oh.. for a beofre shot.. try these..
http://www.cardomain.com/ride/2060495/1
i know they are not as close as the ones i just took.. but maybe you can get the idea of what the spacers did....
Originally Posted by TATTOO
i dont see anything different.
what was the point anyway?>
tattoo... where in FTL are you... you can come by and see it yourself... im in the mcnab road west of powerline area......
That looks good! I have a 35mm offset and I also thought my rear set up is still a little too far back in the wheel well. Thanks for the tip. I now know that I will need 5mm spacers when I'm finished buying my other stuff for my tC! (It just never ends.
) You should be ok with 225s. Especially since you're on TRD Springs. Again, good job!
What's the point? The tC now looks more flush all the way around instead of just up front.
thanks for the pic. im still having a hard time deciding between 215 and 225. do you think the 225 will really make a difference with like rubbing and stuff. im on s techs and i dont want to rub.
oh by the way my rims just came in YAY!!!!!!! and all i can say is that motegi makes some hott A$$ rims.
thanks
thanks
yeah.. the pic's i have up on car domain may not be the best to point out the difference... if i get a chance (but don't count on it
thanks
thanks
what should i measure? this is the first time ive ever had rims so i really dont kno how to measure everything.lol. i finally learned how to read offsets and stuff and that took me a whilte to figure out lol. i do want to get spacers but maybe ill just get like 10 mm.
also what kind of tires are you running? im looking at the g force but want more ideas
