Lowest offset question...
I have a change to get a set of VS-XX Works in 18x8 +34 front and 18x9.5 +32 in the rear. Rubbing issues? Am i am to run this set-up?
I think the rear is a bit extreme, but i had to check.. I did a search and did find this setup..
Does anyone have EXPIERENCE with this set up. I think i am ok in the front. Of course i will be running either 225/40/18 or 35/18 front but dont know in the rear.. 265/40or35/18 or 245/40or35/18... If this is able to work...
Thanks..
Thanks..
you'll rub a little in the rear even with rolled fenders, but it'll look TITE!!! i'd do it anyway lol. since youre on hotchkis springs, you should rub a little if you dont have any car audio in the trunk nor carry rear passengers (you'll be a 2 seater from now on). if youre on coilover (which your sig implies), then crank the rears to the stiffest setting and put 1.5-2 finger gap in the rear to minimize rubbing. dialing in some negative camber helps too.
fronts tires should be 225/40
rears should be 235/40 (maybe 245/40). youre gonna have to stretch the tires. falkens and toyos stretch real good. wider tires will majorly F-up your rear fenders.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
umnitza
Sep 1, 2015 08:06 PM
umnitza
Jul 25, 2015 07:54 PM
