Pressure sensors in the tires....
Old Feb 14, 2006 | 12:46 AM
Garage1217's Avatar
Default Pressure sensors in the tires....
Are they physically in the tires..? can they be transfered to a new set of wheels..? If not, were are they located..?
Old Feb 14, 2006 | 01:34 AM
The_Instigator's Avatar
Its actually the wheel speed sensors that are used for ABS that are also used for tire pressure monitoring. When a tire is low, that wheel will rotate at a different rate than the other wheels. After it gets past a certain point it will trigger the light. You should not have any problems after isntalling new wheels/tires. Just be sure to reset it to the new parts after you install them. The instructions on setting the system are in your owners manual.
Old Feb 14, 2006 | 01:39 AM
Crippie's Avatar
1UP Crew
Great to know!... I had wondered about that... (if I was going to lose this as an option when changing my rims) Thanks guys!
Old Feb 14, 2006 | 08:31 AM
sciontc_mich's Avatar
yes to confirm.. i've seen my wheels without the tires, and no sensors on the wheels.. it is all via the abs sensors..
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
