PSI for Enkei Super 7's
Old Aug 21, 2007 | 10:54 PM
_NeXuS_'s Avatar
Default PSI for Enkei Super 7's
Hey anyone know what Scion says the PSI for front and rear tires when you got the 18" EMX Super 7's?? I dunno cause my sticker only says the PSI for the Stock 17".
Old Aug 21, 2007 | 10:59 PM
Yanki01's Avatar
its not the rim, check the tire .........
Old Aug 21, 2007 | 11:01 PM
_NeXuS_'s Avatar
Tire always says the maximum, but I want the recommended PSI that Scion says for front and rear tires on the Super 7's.
Old Aug 21, 2007 | 11:04 PM
Yanki01's Avatar
what tha.....if the tire says 44, then do 40-42 if your soooo worried about it? Its not that hard and what tires do you have?
Old Aug 21, 2007 | 11:05 PM
Hyghgynx's Avatar
My 18s are 31f and 31r, courtesy of America's Tire Co.
Old Aug 23, 2007 | 07:49 AM
_NeXuS_'s Avatar
Max on tires say 50 PSI i got them at 46 PSI right now. Should I lower it?
Old Aug 23, 2007 | 08:18 AM
Nick06tC's Avatar
Ok, here is a heads up.
DO NOT PUT WHAT THE TIRE SAyS. that is maximum allowed for the tire.
And the reccomended pressure has nothing to do witht he rim. It is all about the vehicle.
No matter what rim or tire you put on a car, it will always call for the same tire pressure. And the owners manual will say what it is. The tC I think is 32 front, 30 rear.
Old Aug 23, 2007 | 05:16 PM
_NeXuS_'s Avatar
Even for 18" and a different tire??? The sticker only tells me for stock 17" with 215/45/17 tires.
Old Aug 23, 2007 | 06:28 PM
Yanki01's Avatar
it will say 17" specs only because thats what comes stock!
Old Aug 23, 2007 | 07:33 PM
_NeXuS_'s Avatar
Well did some searching and found this...
https://www.scionlife.com/forums/vie...ht=correct+psi
So 31 front and 28 rear?
Old Aug 23, 2007 | 08:41 PM
Nick06tC's Avatar
tire size and rim plays no effect on what the PSI should be. In the 40s is WAY to high. You will go through tires in no time at all and wear out in the middle first.
Incase you dont believe me, a simple google brings up thousands of webpages that say what I did.
Here are three reputable sources.
TIRE Rack:
http://www.tirerack.com/tires/tirete...e.jsp?techid=8
Sport Compact car:
http://www.sportcompactcarweb.com/te...ide/index.html
Car Talk.com :
http://www.cartalk.com/content/featu...ips/tires.html
Old Aug 23, 2007 | 10:18 PM
_NeXuS_'s Avatar
Thanks! Already lowered them to 31 front and 29 rear.
Old Aug 29, 2007 | 02:44 PM
J-'s Avatar
J-
Interesting
Old Aug 29, 2007 | 08:48 PM
DiscountTireDirect's Avatar
Nick06TC has some good information but there should be a little clearification. What determines the correct PSI for your tires is a couple of things. One is the vehicles weight (provided by vehicle manufacture) and two is Tire Size. Now you can call the vehicle manufacture, i.e a dealer, and they should be able to get you the correct tire pressure as specified by them. (they currently determine it by math) I would also call the tire manufacture just to double check. Different tire compounds might run optim at different pressures and always watch your wear pattern.
One more thing Also remember the recomended pressures are only valid if you are running the correct width of wheel for your tire, If the wheel is too narrow or too wide for the tire the tread wear, life and performance will be effected. So, Technically speaking, wheels do come into play here too.
To make this easier, I'd ask who ever i bought the wheels and tires from.
Old Aug 31, 2007 | 03:12 AM
_NeXuS_'s Avatar
The wheels are the OEM upgrade rims so there is no issues, Max PSI for my Kumhos are 50, I have them 31 front 29 rear.
Hydryman
Feb 23, 2016 03:35 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
