Removing Rim Paint?
Old 02-03-2010, 05:22 AM
lltysonll's Avatar
lmk which is better bruin: wet mess or sanding 5 hrs.
pretty obvious youll take the wet mess but just lmk how it goes with that bc im about to change my wheel color.
lltysonll is offline
Old 02-03-2010, 08:40 AM
superwhitecoke's Avatar
from what i can tell you, ive painted my rims twice and sanding takes a long time prob about 8 horus (including breaks) to do all 4 wheels and it still had some paint on it,
superwhitecoke is offline
Old 02-04-2010, 08:42 PM
Aroddalobster's Avatar
i used aircraft paint remover on my enkeis. it ate through the rattlecan paint that the previous owner of my rpf1s had painted on within seconds, and continued to chomp through the enkei silver powdercoat that was underneath the bronze rattle-can paint within minutes.
with some
paint om nom nom
ew
win
Needless to say, it MIGHT be a bit overkill just to take off rattlecan paint, but that's your call.
Aroddalobster is offline
Old 02-04-2010, 09:58 PM
whoa!, that looks brand new!
it wont eat through the tire or anything right
Old 02-06-2010, 05:50 AM
lltysonll's Avatar
after seeing that definitely taking that route.
Old 02-06-2010, 07:30 AM
divisii's Avatar
I'd paint over it, the paint just needs something to stick to.
Depending on how nice the original paint turned out (is it peeling, uneven, splatter, orange peel?), you could just go ahead and sand it just enough to rough the surface up, and not take it all the way down. Clean, dry, paint a light coat (or primer), let it dry, paint another light coat, let it dry, paint a final coat.
Now the most important part is, be sure to use clear coat. Just repeat the same steps as for painting. It usually turns out fine for me.
divisii is offline
Old 02-06-2010, 07:36 AM
Scionriderz's Avatar
Originally Posted by pno02
I did not know aluminum could rust. Thats a new one. It might discolor some but aluminum doesnt rust.
Come on man....im a aircraft structural maintainer aluminum is the most common metal i work with it takes time for it to rust than others but it will.
Scionriderz is offline
Old 02-06-2010, 08:07 AM
divisii's Avatar
I'm sure you meant corrosion
Aluminum = corrosion
...only iron will rust
divisii is offline
KILLER
03-29-2015 05:32 PM
JPuehl
Scion tC 2G Wheel & Tire
01-22-2015 02:44 PM
nacy333
44
10-04-2009 11:18 PM
Quick Reply: Removing Rim Paint?
