Old Apr 27, 2010 | 04:28 AM
  #2181
ktothesass's Avatar
hahaa i jus know the photogs so theyre always shooting my car. iono why im still working on my ____ too
Old Apr 27, 2010 | 04:31 AM
  #2182
chicotunner07's Avatar
Really..and how do you know this? Let me know what exactly would need to be done.
basically you would cut the pieces in the yellow boxes, same concept as what Aen did, just applied to the fronts, this would allow you to screw the bottom part further up, therefore giving you alittle more low!
(dont mind the red arrows)
Old Apr 27, 2010 | 04:35 AM
  #2183
dqlostsoulz's Avatar
just saw off that little yellow section? And are you sure it will work?
Old Apr 27, 2010 | 04:38 AM
  #2184
Positive, think about it for a second, lol
when i was installing them i contemplated doing it ahead of time, but i decided to let them be, and im glad i left them alone cuz im more then happy with my drop!
just dont cut any lower then the sway bar bracket and you should be golden!
Old Apr 27, 2010 | 04:44 AM
  #2185
well i might give that a try. And if its too low..lol..than I can just put back a perch ring. How much moar low you think that would give me? As much as I cut off..
Old Apr 27, 2010 | 04:45 AM
  #2186
^too low????????? WHAts tHIS ABOUt TOO LOW!!!!!!! COMING FROM DQ?????????
SOMEONE CALL thE PARAMEDICS!!!! DQ"S HAVING A STROKE!!!!!!!!!
Old Apr 27, 2010 | 04:46 AM
  #2187
haha.. I dont know what I was thinking..
Old Apr 27, 2010 | 04:53 AM
  #2188
phew..... close one, are you sure your DQ??? not someone else logged on as DQ, lmao
but seriously, take a look at them, think about it, once theyre in your hands you will get it and know where to cut!
Old Apr 27, 2010 | 04:54 AM
  #2189
and yes, you will go lower to as much as you cut, i guestimated 1/2 inch, but it may be more, just going off memory/
Old Apr 27, 2010 | 05:02 AM
  #2190
lol..cool if i can get them to go about a 1/2 lower than I just might keep my 17's and get some smaller tires. I was worried about wheel gap, but if it goes about 1/2 in lower than that should be money! Thanks chico...! hey what did aen use to cut it?
Old Apr 27, 2010 | 05:05 AM
  #2191
dont know, dont go crazy with a sawzall, lol
if you dont have access to a cutting jig (something that will cut straight while the piece being cut is being held securely) i think a dremel would be best, just outline the cut and work your way around, finally use a sanding bit to smooth it out
Old Apr 27, 2010 | 05:07 AM
  #2192
nice i have a dremel.
Old Apr 27, 2010 | 05:15 AM
  #2193
^awesome, best tool i have ever bought, i literally use it for everything, lol
Old Apr 27, 2010 | 06:30 AM
  #2194
BlkTC's Avatar
so yyeah... or, you can buy some B+G coilovers.. lol
  #2195
ktothesass's Avatar
2nd that^
Old Apr 27, 2010 | 06:49 AM
  #2196
wild1413's Avatar
^lol!..
Old Apr 27, 2010 | 07:09 AM
  #2197
shinjitai's Avatar
if i remember correctly, i tried doing that... but i found out it wouldn't work. its because the bottom most cylinder, the one you can adjust at the bottom, screws where the yellow boxes are. So if u tried to cut them, then u cant screw the bottom part.
Old Apr 27, 2010 | 07:16 AM
  #2198
wild1413's Avatar
hay shinjitai wat happened to ur back fender?..
  #2199
but the whole bottom part screws.
Old Apr 27, 2010 | 07:19 AM
  #2200
wild1413's Avatar
just sell the 19s man and buy sum new coilovers and sell the ones u are on now!..
