dope. im down. im not running camber right now, but once those rotas are in, ill be set. ive already installed my spc camber arms in the rear.
and if u wanna go lower, u should remove some perch rings. u should be good with that. btw, whats the specs on ur grids? 18x9.5 +35?
yeah i want to remove the front 2 perches but i'm lazy as fuuu. and damn, camber arms? the stock camber goes to -4 degrees, aren't Socal's wheels the same specs as mine or fairly similar?
mine are 18x9.5 F: et38, R: et23 (after 15mm spacers).
but a shoot with all three of us would be super dope though.
i thought stock rears only did up to 3? hmmm. well, the spc arms add like another 2 degrees i think.
and his rotas are 18x9.5 +35 all around. once i get those, i might pick up either 15 or 20 mm for the rears. havnt decided yet.
hmmm, well i just googled it. says it adds and subtracts 1.25. depending how much stock does, it should do both ways.
http://www.racinglab.com/spc-camber-kit-scion-002.html
You gotta read the description bro. SPC Rear Arm:
This fixed change arm is ideal for correcting excessive negative camber issues seen in lowered Scion tC's. The Scion tC comes from the factory with a cam bolt that provides ±1.25 degree. This factory change is not enough change for lowered applications. By increasing the length of the rear upper control arm SPC Performance adds 2 degree positive camber to the rear suspension that can then be dialed in with the OEM cam bolt.
67485 (Adjustment range: -1.25 degree to +1.25 degree.)
