What do you guys do to keep the front bumper and front fenders fitted correctly after a pull? My front fenders are pulled out about 1/2 inch and my bumpers are sitting in and not only does it look bad, it rubs like a motherfuuuu. I tried zip ties but it isn't quite working for me. :shrug:
didn't do any thing just a hand pull and bent the bumper tab up just so it don't touch the tire. and specs on wheels are 18x9.5 et +30 front and the rear is rolled and pulled wheels are 18x9.5 et +10 has a 20mm spacer .
What are you guys using to roll your fenders? and are you running camber in the front? I'm having trouble grasping how to get lower on my coils. I still have like 15-20 threads left on my racelands in the front on my 18x8 et 35 with 225/40/18
Irish guy, you'll be okay if you drop the coilovers all the way down. You will rub on the fender liners a bit but a roll wouldn't hurt.
Try to find someone with an eastwood roller. Search that in craigslist too, some shops do it.
im still rolling on my winter rims which are 18x8 40, 225 40 18 and 1 thread left on racelands no rub, just have to take out the front fenderliners and push in the front bumper tab.
^ For anyone on similar specs: 18x9.5 +38. I did some more work today. Again, couldn't get the 17mm spacers on the rear. One of the recesses on the Enkeis is keeping me from fitting it correctly. I just need to cut a stud and run more stretch.
^x2 Slip-on spacer w/extended studs. If the grind fix is being done for just one wheel then when it's time for going back to running without spacer he'll have to replace with a new wheel stud anyway.
^Maybe for some ARP or uber JDM ones lol. Ichiba sells extended for 2.49 each.
A set of 5 extended ARP studs...
http://www.ptuning.com/html/Item-Des...l&ModelDesc=tC
Here boys and girls, is a grrrrreat example of thinking you can align your toe correctly:
Yes yes, my mistake i'm dumb mea culpa.
But, on the bright side I got a whopping deal on some bfg 205/50/17's on craigslist so now I'll fill in that rear a lot better.(thought I was gonna have to run the 215/50's from my stockies... I'm on them now and I cant turn much in the front, they're so dang tall.)
^Yeah, I get terrible gas mileage. Found a drive on alignment rack. They need 4'' of clearance so I figure I'll go on my stockies and it'll be close but I should get on.
Also, I've had those tires for 3 months... lol
