Old Feb 24, 2012 | 08:24 PM
  #9661
chubbykai's Avatar
Originally Posted by Yay Jaw Knee
Ahhh.. WTF?? So they aren't 15mm? Which should only be a little over half an inch...
These adapters are actually 1.5 inches????
...k now im confused. Also, around how low in the offset numbers can i go without doing major fender work? I dont mind a slight pull but nothing major.
with 9.5 in the rear, i'd say lowest offest you can go without major fender work is +15, and it also depends on how much you stretch your tires. im running 9.5 all around +30 and maxed out camber with rolled fenders on 235's and i rub a bit. if i were to slim my tires down to 225 or 215 even, i can clear no problem.
going negative offset is insane and awesome, but requires some major fender modification
Old Feb 24, 2012 | 08:30 PM
  #9662
Jasper Ash's Avatar
^ I'm running lower offsets on a 9.5 than +15, but with a 215 tire. Stretch really does quite a bit. Camber as well.
Old Feb 24, 2012 | 08:33 PM
  #9663
chubbykai's Avatar
good to know. i was considering changing out the 235 to 215, but i got the 235 continental dw's for such a good deal haha. i kind of wish there was a way to achieve a tad bit more camber after you max out.
Old Feb 24, 2012 | 08:52 PM
  #9664
Jon's Avatar
Jon
Moderator
Moderator
The ones in the link are 15mm. That would put you at +20 (35-15). But to run less than 25mm adapters, you have to make sure your wheels have the pockets in between the holes on the mounting pad so your stock studs can have room. Otherwise you'll have to shave them down until their flush (or a little less) with the adapter.
Old Feb 24, 2012 | 09:16 PM
  #9665
Yay Jaw Knee's Avatar
^^ WOW! Explanation was ON point JON! I've always had trouble understanding the whole adapter concept and i understand now. I think i freaking lucked out because i have gaps for the 15mm to fit!!!
Correct me if im wrong.. Took a pic for reference:
Old Feb 24, 2012 | 09:17 PM
  #9666
Thank you guys. Big help as well!
Old Feb 24, 2012 | 09:20 PM
  #9667
Jon's Avatar
Jon
Moderator
Moderator
No problem man. And yeah that's what I'm talking about. Those are pretty deep so you should have no problem. Also get the center bore of the wheels measured if you don't know already so they can make the ring the right size on the adapter to prevent vibration.
Old Feb 24, 2012 | 09:27 PM
  #9668
OK. I'll definitely do that. I didn't realize that was important.
I guess i'll google how to measure it. Or would this have to be done by a shop or something?
Old Feb 24, 2012 | 09:34 PM
  #9669
Jon's Avatar
Jon
Moderator
Moderator
You can try calling Discount Tire or another shop that deals with aftermarket wheels. They should have a tool to measure it. You could do it yourself, but you need to know the inner diameter wall to wall, not on the top. It needs to be to a tenth of a millimeter.
Old Feb 24, 2012 | 09:40 PM
  #9670
Thank you, Sir.
Old Feb 25, 2012 | 01:09 PM
  #9671
ThaHMan's Avatar
Originally Posted by Jon
Dial in some negative camber.
Would this be my only option?
Old Feb 25, 2012 | 02:36 PM
  #9672
Jasper Ash's Avatar
^ You could also run smaller tires. Since you're on springs and the wheels are not very wide you wont need a lot of stretch. Maybe go down a tire size or two. Those are pretty much your only options unless you want to mess with the fenders.
Old Feb 26, 2012 | 09:17 PM
  #9673
pena1128's Avatar
Never really posted pics of my wheels or car.....so here it goes..
Old Feb 26, 2012 | 10:03 PM
  #9674
gmc_113's Avatar
There not really aggressive. But there awesome looking
Old Feb 27, 2012 | 01:53 AM
  #9675
Irishguy0224's Avatar
like he said ^^ not aggressive, but nice wheels man!
Old Feb 27, 2012 | 02:58 AM
  #9676
midnight_blue's Avatar
is it me or does your front tires look flat?
Old Feb 27, 2012 | 03:34 AM
  #9677
yellowxhoodie's Avatar
I was gonna say, looks like it needs a higher tire. Those things look tiny.
Old Feb 27, 2012 | 04:24 AM
  #9678
gmc_113's Avatar
Coulda been done to make the car look lower? Drained the air for the typical key against lip photo op?
Old Feb 27, 2012 | 06:54 AM
  #9679
pena1128's Avatar
Didn't "drain air"out just to take a picture. Never even crossed my mind. How much psi do you consider the right amount?
Old Feb 27, 2012 | 07:55 AM
  #9680
i_pogi's Avatar
how to go lower!!!!?! i have racelands any ideas?
