rim size range inquiry
Old May 6, 2008 | 08:29 AM
KraXxuS's Avatar
Default rim size range inquiry
Looking to get a new set of rims for my tC. Probably 18's. Not everything I see is available in 7.5 width (width of stock 17" rim). Can I do 8, or 8.5 width without any fender rub? Obviously smaller width is possible, but with loss of handling. Or should I just get what I can with 7.5" width to minimize risk of fender ruband keep it as close to stock as possible? I think the 18's that come optional with the tC are 7.5" width also. My suspension is still stock, but future plans for TRD shocks/coils exist in my brain so if I could lower my car safely without rub that'd be awesome.
I'm assuming that 18, 19 inch rim etc would have more risk of rubbing inner fender well just because it's bigger, even if it's the stock width (7.5") and if you were to get lets say 16's you could get wider rims/tires? If all that's wrong and changing your rim won't change it's distance from the inner fender well (for smaller rims at least) lemme know.
I guess I'm looking for a tC guru or something...
Thanks for everyones help in advance...These forums always help me out in my quest for aftermarket stuph for my favorite car ever.
Old May 6, 2008 | 12:09 PM
PAUK's Avatar
i was running on 18x8.5 rims with 235/40/18 tires and dropped on trd springs and no rubbing at all, so u should be fine
Old May 6, 2008 | 03:29 PM
Leo_EdgeRacing's Avatar
You'll be able to run 18x8 and 18x8.5 with a 35 offset if you have TRD suspension.
Old May 7, 2008 | 12:04 AM
KraXxuS's Avatar
So even less chance with stock suspension on those sizes. Awesome. And I can still get the TRD coilovers eventually too. Thanks a ton you two!
Old May 7, 2008 | 12:06 AM
Punisher_tC's Avatar
when you get the coilovers just make sure your ready in a cuple of weeks to get the aftermarket shocks too
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
blh72
Jan 31, 2015 03:41 PM
Genesis
64
Jan 22, 2005 01:02 PM
