rota boost sizes for my TC
Old Jan 4, 2007 | 02:35 AM
irwin07's Avatar
Default rota boost sizes for my TC
alright, i want to get these for my 07 tc, i'm getting tein s-tech w/ the 2" drop all around for it before i put them on and want to know the offset for them, i dont want a weak offset so there sucked in, will a +25 work with a 17x8
let me know, thanks, IRWIN
Old Jan 4, 2007 | 03:57 AM
tikbhoy's Avatar
s tech is sorta a rake style lowering, 2.5 f 2 r
your rims will stick out 20mm from stock! am i right ?
Old Jan 4, 2007 | 04:04 AM
JQ's Avatar
JQ
Here is a really good calculator to help determin the inner clearence and how far out a rim offset will look compaired to stock.
http://www.1010tires.com/WheelOffsetCalculator.asp
FYI
Stock 17 X 7 w/ 45 offsett
And BTW with a 17X8 w/ 25 offset you will have 7mm more inner clearence and 33mm more in the outer position!! that is 1.29' inches!
hope this helps
Old Jan 8, 2007 | 11:06 PM
GReddyTC's Avatar
Stech are not a raked lowering they even out the uneven factory height. This would make the wheels stick out 33mm each. I dont think they will fit. I just ordered, 17x8 et35. They are going to be tight as it is. I will let you know how much clearance there is once I get them installed.
Old Jan 10, 2007 | 03:18 AM
fairladyz541's Avatar
Team Sushi
Since we are on the topic of Rota wheels will these fit on S-techs......
Size: 16 x 7.0
Lug: 5x100
Offset: 45 or 48
What offset would one get if they would. 45 or 48.
Old Jan 10, 2007 | 04:03 AM
JQ's Avatar
JQ
Size: 16 x 7.0
Lug: 5x100
Offset: 45 or 48
With the 16 x 7 +45 it would look the same as your stock wheel. Meaning same inner and outter settings. (stock is 17 x 7 +45)
As for the 16 x 7 +48 the inner would be 3mm less clearence, and the outter would be RETRACTED by 3mm.
Both will fit. Hope this helps
Old Jan 10, 2007 | 04:07 AM
Team Sushi
Thanks helps out a lot. So, they both fit........But, what would be the best for looks with spacers to make it look flush and what spacers would one use.
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
blh72
Jan 31, 2015 03:41 PM
