spacers????
Old Feb 3, 2007 | 11:54 AM
pinkstonm's Avatar
Default spacers????
Someone explain spacers to me.
What do they do
Where do you get them
Why do you use them
Pictures????
Old Feb 3, 2007 | 12:10 PM
soros151's Avatar
watching
Old Feb 3, 2007 | 12:38 PM
CustomTuners's Avatar
Spacers push the wheels out. mainly for big breaks. cosmetically the make the wheels look wider by tucking them right under the fender. the may help handling a little. depends how wide you get. you have to be careful not to go to wide though. These work good if you are doing a wide body kit and don't have the money for custom wheels/offset. ebay has smaller ones. wheeladapter.com are wider ones. you could actually change the bolt pattern with them as well. which isn't really necessary because the scion has a common pattern. Go with hub centric as well.
Old Feb 3, 2007 | 03:47 PM
trdtcpr's Avatar
^great info!
Old Feb 3, 2007 | 08:58 PM
soros151's Avatar
So, what would be the farthest one could go out with the stock wheels, and to have better handling car?
Old Feb 3, 2007 | 10:47 PM
well you would have to see how much space you have between the outside of the tire and the inside of the fender. Keep it just inside that so the tire wont rub if you are lowered or hit a big bump.
Old Feb 4, 2007 | 03:59 PM
soros151's Avatar
I have some htechs in by the way, and I have som camber. I will check how much space is in there.
Old Feb 5, 2007 | 06:46 AM
captainlaziness's Avatar
I'm curious as to how wide of a spacer one could run without needing to install new studs. Anyone?
Old Feb 5, 2007 | 07:03 AM
Neothin's Avatar
5mm. max. I wouldnt even do that to tel you the truth. I like having the peace of mind that the studs are providing all the threads that they can.
Old Feb 5, 2007 | 12:41 PM
yeah, you dont want to mess with that. if you go wide, get the ones with the studs in them.
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
reniculous1
Aug 14, 2015 03:16 PM
