Style 5s (bbs). BMW on tc - help ?adapters? Spacing ?
Old Mar 12, 2013 | 11:39 AM
dguzzardo22's Avatar
Default Style 5s (bbs). BMW on tc - help ?adapters? Spacing ?
I have a set bbs style 5 wheels off my 5 series I'm Gonna refinish them and put them on my gf tc .
Question is how much of a spacer do I need in the front and back if I were to get alil stance ?
I'm gonna look for some lowering springs also and pretty much get her in the stanced flush look is what were going for.
Old Mar 12, 2013 | 06:16 PM
HKSpeed's Avatar
Look at this post, but I think this guy had his style 5's redrilled.
https://www.scionlife.com/forums/sho...postcount=9983
I think there was a silver and/or dark blue tC that ran style 5s years ago.
Old Mar 12, 2013 | 07:40 PM
Jon's Avatar
Jon
Moderator
Moderator
It's been done more than once. I wouldn't recommend springs since you'll be at a -5 offset with adapters.
https://www.scionlife.com/forums/sho...postcount=1436
Old Mar 12, 2013 | 08:18 PM
So adapters are the best way to go I guess .
Old Mar 12, 2013 | 09:34 PM
HKSpeed's Avatar
SL user Hayseed used to run Style 5s but I cant seem to find any photos.
This dude looks like he's running adapters.
https://www.scionlife.com/forums/sho...postcount=8849
Old Mar 12, 2013 | 11:54 PM
Irishguy0224's Avatar
i ran them in the same specs Hayseed did (actually his old wheels) i used 20mm adpaters and had to cut my studs to sit flush. So they were 17x8 +0... prepare for fender work! lol
Old Mar 12, 2013 | 11:58 PM
Define your fender work ?
And I'm looking into adapters so where to buy ?
Old Mar 13, 2013 | 01:03 AM
it completely depends on how long she is going to be. But from all the wheels i have run, everything from those 17x8 +0 to 17x10.5 +20 and 18x10's i have fully rolled my fenders, cut all tabs and cut the inside of my bumpers. Also i have no fender liners.
I bought my spacers from Adaptec USA
Old Mar 13, 2013 | 01:04 AM
Old Mar 13, 2013 | 05:05 AM
Oh ok so once I get the wheels mounted then focus on drop .
Old Mar 16, 2013 | 02:34 PM
dropzone's Avatar
HKSpeed, I had the wheels drilled, still keeping the 5x120 pattern. The wheels just barely clear the calipers up front, it's close. The shop didn't drill the lug seat as deep as on my TRD wheels, forcing me to get extended wheel studs(because 4 turns just isn't safe to tighten down a wheel). I think one that was 5mm longer would have worked fine but went all out with ARP extended wheel studs for an IS300 because I plan on running spacers anyway. Plenty of pics of the setup can be found on my flickr page. The rears I had the fender rolled for minor tire rubbing, it could have been done without it if I had Falken 512s instead of the Capitols and a touch more negative camber(currently it's at about -1.7*)
Idea of expenses the route I went for those that want to compare with spacer adapters,
Wheel drill cost $200(if one shops around it can be done for less, the shop wanted to charge extra for filling the holes, so I told them just drill)
ARP extended wheel studs ~$120
Open end lug nuts ~$54
Hubcentric rings(aluminum) ~$20-$25
http://www.flickr.com/photos/61201863@N07/7174114208/
Why did I go that route, ARP makes strong wheel studs, and there's been posts of lugnuts being broken and sheared from OEM to those on the adapters themselves. Now I have the tC OEM 17s on my 89 Celica with 25mm H&R spacers in the rear and have had no problems for the year plus they've been installed, so there's other factors as to why some spacers/adapters have failed(improper install to just being defective).
k1114
43
Mar 1, 2023 03:08 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
umnitza
Sep 1, 2015 08:06 PM
adorable
Jun 23, 2008 02:56 AM
asml8
25
Dec 30, 2005 10:41 AM
