tC Painted Stock Rims
Originally Posted by kayi078
anyone has stock aluminum rim painted to silver color ???
they come painted silver.
honestly... I dont mind the stock color.... I do like some other custom colors... but biggest prob I have with the stock silver... is the damn finish on them is so frickin' soft that if you even look at them wrong ...BAM! there's a nick in the finish.
my buddy has a silver civic with silver rims and i love the way it looks.
if you want them color matched, id suggest doing all the prep work yourself than take them to a body shop to have them painted.
you could always use those little color matched spray cans too.
Etching primer...what the hell is this???? what should i need really need to use if i want to paint them silver
1,paint thinner
2,sanding
3,color paint at last??
or
1,paint thinner
2,sanding
3,primer
4,color paint
or
1,sanding
2,color paint
do we need primer in our aluminum tc wheels????
clean
sand
clean
paint
clear
theres a whole DIY on here for it.
search and youll find what you need
sand
clean
paint
clear
Originally Posted by Obsoletepunk04
It would help with adhesion.
Clean
Sand w/ 400 grit
Clean
Prime
Color
Clear
...for the most part thats all you need.
Clean
Sand w/ 400 grit
Clean
Prime
Color
Clear
I guess paint thinner would work. Any kind of wax and grease remover should work. Well you can do either or. You could wet sand using your wax and grease remover as the lubricant (heh). Kinda doing two things at once then.
personally, i stay away from the paint thinner.
reason being...if you do use it you have the clean the wheels ridiculously good before you paint them.
if you have even the smallest spot of paint thinner that didnt get cleaned off its gonna fk up the new paint and your going to have to re-do the whole thing.
This is what I did...
1. I cleaned the rims really good with greased lightning blast
2. Wet sanded the rim w/600 grit sand paper
3. Then washed it again with greased lightning blast
4. Dried it off with a lint-free cloth
5. Taped up eveything I did not want painted with blue painters tape(xpensive stuff)
6. Then I used dupli.color prep-wipe and wiped off the rim.
7. Sprayed a few light coats waited a few min. in between then went a little heavier with the coats....nice even strokes to prevent drips and sags.
8. Waited a about 10 min after I finished spraying the paint the added several coats of clear.
And whaaaalaaaa.....check them out.....
https://www.scionlife.com/forums/vie...670&highlight=
My brother originally had n aluminum finish all i did was wet sand w/600 grit wet dried it off good tacked it off for any dirt and sprayed 3 coats of dupli color auto paint and turned out great.
