TPMS Question, Tried the search button..
I have an '08 tC, obviously with the TPMS. I want to put some winter tires and steel wheels on the car. If I don't spend the money for pressure sensors in the wheels, what will happen? I can live with a yellow light on my dash for the winter if that is all that will happen. Thanks for any help!
-Brian
-Brian
Car will drive fine with light on.......at least that is what I understand from the dealership mechanic.why pay to transfer.......if you get a flat you will know........and killing a steelie is no big deal.....
if youre going to swap than you might encounter what happened to this guy:
https://www.scionlife.com/forums/viewtopic.php?t=195489
07 and plus have TPMS, so it will be the same. I advise that you transfer the sensors cause most people can't stand to see the tire pressure light on their dash.
The transfer is mad easy but it takes time to change each one. And don't go to the dealer cause they will overcharge, or refuse to do it claiming it will void your warranty.
Thanks for the advice! I'm not worried about having the light on the dash. I wasn't sure if the system was tied into the ABS or something else that would affect the car. I don't want to swap the sensors because then they'll have to be swapped back in spring.
-Brian
-Brian
bootlgr
Jan 26, 2016 01:22 AM
