Vibrations with new wheels, help please.
Old Jul 1, 2008 | 10:45 PM
Jspec's Avatar
Default Vibrations with new wheels, help please.
I have an 06 tc and I just put on a set of 18x8 Konig Sideways. I got the mounted and balanced and took the car around the block. I get a lot of vibrations when I go past 70mph and it gets worst the faster I go. I know my needs an alignment but I don't know if that would fix that problem. I also read somewhere about maybe needing hub centric rings but I have no clue what those are or what they do. If someone can help me out, I would appreciate it, thanks.
Jason
Old Jul 1, 2008 | 10:47 PM
MrBurrito's Avatar
it could just be the way u mounted them on the car and to check to make they are really tightened down also r u using the oem lugs or aftermarket lugs
Old Jul 1, 2008 | 10:49 PM
fujita_TC's Avatar
you just answered you're own question, its either alignment or hub centric rings, ill start with the hub centric rings......instead of getting an alignment and realized it was the hub centric rings then you have take off the wheel again and put the rings and get it realigned.. go to discount tire or any tire shop they carry those centric rings.
Old Jul 1, 2008 | 10:50 PM
Jspec's Avatar
I am using aftermarket lug nuts. I didn't think oem would fit or at lease that's what I was told. I will try tighten them down before I leave work and see if there is any improvement driving home tonight.
Old Jul 1, 2008 | 10:53 PM
tC_2NeR's Avatar
u need hub rings....simple fix
Old Jul 1, 2008 | 10:54 PM
DonNguyen's Avatar
be careful not to over torque your lugs...you risk breaking a lug stud...
Old Jul 1, 2008 | 10:58 PM
Jspec's Avatar
Can someone post some links for centric hub ring? I've done a search and found different ones with different sizes and I have no clue what size I am looking for.
On the over torque part, how much torque is correct and how much is too much? I will go downstairs to the shop and get a torque wrench to tighten the lug nuts down.
Old Jul 1, 2008 | 11:00 PM
Hyghgynx's Avatar
Yep yep.
Old Jul 1, 2008 | 11:02 PM
Hyghgynx's Avatar
Try this link...
http://www.justforwheels.com/index.j...=how&track=GHR
If you don't buy there, at least you'll know your size.
Old Jul 1, 2008 | 11:16 PM
Jspec's Avatar
Thanks for all the help guys!
Old Jul 1, 2008 | 11:43 PM
Hyghgynx's Avatar
Holy ____e!! I didn't even notice the huge "Justforwheels.com" banner at the bottom of the page!!
Now it's K&N Filters. But it did say, "Got vibration troubles?" and had a link for said site.
Old Jul 2, 2008 | 03:40 AM
ScionJim23's Avatar
you need hub centric rings. i installed them on my wheels....no more vibration. smooth as butter now.
Old Jul 2, 2008 | 03:41 AM
CarbonXe's Avatar
Mine said that too.
Old Jul 2, 2008 | 04:14 AM
ninjaionsobe's Avatar
must be a new algorithm for ads. I have seen it happen in a few topic's
to help you out the inside is 54.1mm
XirtaXa
24
Jan 14, 2025 03:49 PM
fur_pig
Mar 20, 2020 04:28 PM
merotty
9
Mar 9, 2015 05:27 AM
jenkay
Dec 17, 2014 03:25 PM
ChickenAdobo
Oct 16, 2003 03:57 PM
