Who has 18" 's with a 38 Offset??? Or close to it....
Old Apr 18, 2006 | 12:18 AM
SCION_X's Avatar
Default Who has 18" 's with a 38 Offset??? Or close to it....
Alright guys i am looking for some pics of 18" 's with an offset of 38 or close to that offset as possible... i want to see how they look on our tC's..... PICS PLEASE.... thanks...
oh and please state the tire sizes as well...
Old Apr 18, 2006 | 12:20 AM
Kilo6_one's Avatar
most guys are running 38mm offsets on there 18's ill post up some pics later.
Old Apr 18, 2006 | 12:21 AM
tC9o9's Avatar
here's mine..
18x7.5 +42 tire size 215/40/18 lowered on h-techs
Old Apr 18, 2006 | 12:26 AM
SCION_X's Avatar
sweet... i see that its a 42 offset.. would 38 stick in more? or out?
i will be going with 225/35/18 front and 235/40/18 rear.... and 18x8
Old Apr 18, 2006 | 12:31 AM
gustavito24's Avatar
www.edgeracing.com
there is a picture of a white tc with 18 x 8 35 et...
Old Apr 18, 2006 | 12:38 AM
Hyghgynx's Avatar
Here's mine. 18" 5Zigen RX6s in Hyper Black w/35mm Offset
*Front*
*Rear*
*Finished*
35mm is almost flush in the front. The rear, as you can see, is still tucked. So 38mm would be tucked ever so slightly in comparison to 35mm.
Old Apr 18, 2006 | 01:02 AM
tC9o9's Avatar
a 38 offset would push the wheel out 4mm more..meaning it will stick out more.
and whats the point of running thicker tires in the rear?
and i highly recomend that you do not purchase a 35 series tire for your front unless you like buying tires every other month
Old Apr 18, 2006 | 01:14 AM
SCION_X's Avatar
ok, what about 19's... 225/35/19? are you saying that i will have to buy new tires all the time?? What tires are you buying? the Falken st115 have a good treadlife..
Old Apr 18, 2006 | 01:18 AM
tC9o9's Avatar
NONONO..its not about the tire quality, its about the size. ask anyone who has 19's how often their tires pop or go flat. usually people with 19's run 35's.. i recomend 40+ for tires..you can fit more rubber if you wanted, i have never heard of people going with less. and one more thing..we are FWD..so more meatier tires up front rather than the rear
Old Apr 18, 2006 | 01:27 AM
SCION_X's Avatar
oh ok... but if i go 19's i dont think 40's will fit??? and on most drops...
Old Apr 18, 2006 | 02:15 AM
Kilo6_one's Avatar
sounds like a load of crap ( no offense blackonblack).....i had 225/35 on my 19's and never had any issues period. you run a 40 series your overall diameter will be larger then it needs to be and you will have other issues. rubbing for one.
the correct size is a 225/35-19 or 235/35-19 the tires will last you as long as you take care of them rotate them etc. my accord has 35 series and has never had a single problem. my denali had 30 series and that thing weighed twice as much as a Tc and it sat on 22"s and i never had a problem, tires are not ballons and will not just pop at random, 95% of all tire damage is opertor error, the other 5% is actually a defective tire.
if you really want to know about tires, call americas tire, ask for kurt he knows pretty much everything about about tires.
Old Apr 18, 2006 | 02:25 AM
dex's Avatar
dex
im running 18x8 with a +36 offset and 225/40 R18's. fills out the wheel well perfectly.
Old Apr 18, 2006 | 02:27 AM
SCION_X's Avatar
sweet.. i sent you a PM asking where you got yours.... and how much.. pop me a PM or write here... thanks..
Old Apr 18, 2006 | 03:34 AM
Kilo6_one's Avatar
BTW, if you get your tires from discount tire, or tirerack for a few bucks more they have a nofault replacement warranty you can buy, so if you "pop" a tire even if its your fault they will replace it, check it out, i buy all my tires with the warranty, you never know.
good luck!
Old Apr 29, 2006 | 05:48 AM
Kennopee's Avatar
Heya fellas ...
I was thinking about posting another topic, but i figure i'll ask my question here since my wheel specs are close.
I am running Enkei GF1 which are 18x7.5. I got Nitto NeoGens 235/40r18. My suspension are Eibach ProKits which is 1.4inch drop. I notice rubbing when I hit bumps even minor small bumps. the rubbing sound like it comes from the front. When i drive on good roads there's no rubbing. Is that a normal thing to be rubbing when i hit a bump? How do i fix that?
Old Apr 29, 2006 | 06:54 AM
jrv2000's Avatar
Well its normal that you are hearing this because of the offset of your wheels, but its not a good thing. The only way you can get this corrected is if you get your fenders rolled.
Here are some of my pics btw...
John
Old Apr 29, 2006 | 09:04 AM
mwuf15's Avatar
so what's a good offset with 18" rims. and what's a good tire size for it?
Old Apr 29, 2006 | 07:24 PM
Hyghgynx's Avatar
I would say 35 or 36mm. They both are almost flush. On tires, I would have to say 225/40s. You could go with 235s, but you might get some rubbing issues in the front. I have had my 18"s with Pirelli PZero Nero 225/40s for almost a year now with absolutely no rubbing what so ever. This is just my opinion. Others, I'm sure, will chime in as well.
Old Apr 29, 2006 | 08:12 PM
Kilo6_one's Avatar
CHIME!
Old Apr 29, 2006 | 08:19 PM
Garage1217's Avatar
these are 18x7.5" 35 offset 5 zigen hyper 5zr's with 225/40/18 falken 512's...
I have 0 rubbing issues with this tire / wheel combo on h-techs. Tossed her into some nasty corners as well with no running.
