Widest wheel to fit on tC?
Heys guys... Just wondering what's the widest wheel I can fit on the tC? I just purchased a tC the other day and I'm already bored to tears with it. I think it needs some track time (and a set of analog controls).
I was thinking of going with a 16x10, or at the narrowest, 16x8 with a 48mm offset. I have custom 9.6kg front and 10.2kg rear Eibach/ground controls and Koni Yellows for my stance.
Any help would be appreciated.
p.s. has anyone yet conceived an idea of how to swap out the drive-by-wire system with a traditional cable setup?
i know the drive by wire has been changed to a throttle cable but it was done to that one civic si thats made too look like a race car however i am un-sure of how it was accomplished but obviously it can be done but just about anything can be done with enough money so... who knows man
I have 18x9, ET24. I think you could fit a 10 inch wide wheel at ET45. at that point you couldn't lower the car more than 2 inches, stretch the hell out of the tires, and roll the rear fenders.
Maybe a cable throttle system could be used from other 2AZ-FE equipped cars like the previous Camry or RAV4 (assuming they use throttle cables).
The new Civic Si is drive by wire, but I read you can use the throttle cable system from a RSX or EP hatch.
__________________
__________________
Originally Posted by HKSpeed
i have 18x9, et24. i think you could fit a 10 inch wide wheel at et45. at that point you couldnt lower the car more than 2 inches, stretch the hell out of the tires, and roll the rear fenders.
maybe a cable throttle system could be used from other 2azfe equipped cars like the previous camry or rav4 (assuming they use throttle cables). the new civic SI is drive by wire, but i read you can use the throttle cable system from a RSX or EP hatch.
I'll try to look further into that cable conversion idea. I'm sure it's been a nuisance to others aswell.
Im currently doing 18x8.5 but thats gonna change soon
As for the wire why? Are you making this a stright track car... I know theres a slight pause on this system and that it acts wierd on some turbos but dude why?
Also, this is my first Toyota. I've been a Honda tech head since the EF's. Honda kind of dissapointed me with its oddly unintimate UFO styling of the new civic, but I needed a new toy car. I'm still trying to get used to the idea of something that doesn't have cable controls and rev to 8k.
Originally Posted by _NeXuS_
The best widest tire you could fit and offers the best performance is an 17X8 rim with 45+ offset wrapped with 245/40/17 you will hug corners with that setup thats the setup I want.
Yeah I think so make sure its an offset of 45 or more 17X8 rim with H-techs its possible ive seen the setup with TRD springs if I remember its not much of a difference in the drop. I want that setup so bad love wide ___ tires
I want to get this rims along with 245/40/17
http://www.discounttiredirect.com/di...&rw=8&bp=5-100
Daang nice rims!! Do they actually imporve handling? I would go with light 17's, I wouldnt go with 16" on wide tires 17"'s will suit you fine.
Wheels that big (heavy) are going to hurt perfomance. They have a much larger contact patch, but the suspension is going to be working hard to keep the wheels in check.
sorry to jack your thread yadeadson but it has to do with the throttle...does anyone know how i can adjust the idle of the ect? because mine sits a little low i feel like at 600 and i thought it usually should be at like 750 (rpm's) and i don't feel like taking it to the dealer oh and btw i have sri intake, trd exhaust and dc sports headers if that makes any difference thanks
