will 5x108 fit on 5x100 or is there an adapter
i dont know much info on them i know they were on a 03 ford taurus and i believe the lug pattern for that car is 5x108 and tomorrow i will see him at work ill ask to take pictures and what do u mean it depends ....is there still hope lol??
After some quick Google-ing, it seems that most spacer/adapters range in thickness from 5mm-60mm. I think (someone correct me if I'm wrong) that an extra 5mm added to the hub won't require new studs. I found this site which makes custom spacer/adapters:
http://www.wheeladapter.com/wheel_ad...el_spacers.asp
Maybe try shootin' them an email and see what they say.
Fitment depends on more than just the bolt pattern. Diameter, width, and offset (in combination with tire size and suspension) dtermine whether or not a wheel will fit.
well the tires are kind of thick themselves and with a adapter they may rub ......the tires are 225/40/r18 if that helps....so is there a big difference in the bolt patterns because my cousin thinks it wouldnt be much of a difference and they may fit but we dont know??
i wouldnt risk ghetto rigging wheels man, theyre the only thing connecting you to the ground. im sure you can find a adapter somewhere, except im not sure if they even make 5x100 to 5x108 ones. 5x108 is kinda rare for bolt pattern. but if you get the 225/40/18s you wont rub. even with a 5mm spacer. oh and you dont need need extended lugs for 5mm spacers.
Originally Posted by Cabana
damn, 5x108? surely you can find some 5x100 wheels. I had 5x108 on my last car (Taurus SHO) and there isn't much good because so few cars use that pattern.
SubrinaIsMyCar
Mar 8, 2015 07:53 AM
MyNameIsMud
Scion FR-S ICE & Interior
Mar 4, 2015 05:27 PM
clickclickw00t
Feb 18, 2015 08:57 PM
