Will these sexy rims fit?
I did a search, nothing CIA-like
Just want to know if these rims in these sizes would fit on my car. all experts please HELP!!!
Front:5Zigen FN01R-C 17x7 w/ 35mm offset
Rear:5Zigen FN01R-C 17x8 w/ 48mm offset
Keep in mind that I'm on Progress coilovers. Thanks.
I think I'm a little confused on this whole offset thing. Is it the measurement of the lip? Anyways any help would be appreciated.
I would like my rims to look like the ones in the pic. with a nice lip to it like the one pictured above. And does anyone know where I can get a good price on these?
35 offset might be a bit much in the front, could lead to rubbing issues if you're dropped low.
the rear would be fine, might be a little tucked for my tastes, also don't think it'll look right with flush fronts and a tucked rear.
Also the wheel in the picture is at an offset and width that 350z's, 240sx, etc would use, the spokes will not sink in like that on the tC.
Ok so I just have to add something.... how are you going to say that a 35 mm offset is TOO tucked into the wheel well when our stock scions have a 45 mm offset??? that makes no sense... the 35 mm offset would put the wheels OUT of the wheel well exactly 1 cm (or 10 mm) ...
the offset of a rim is how far from the center of the rim you find the bolt holes for the lugs.... it can either be positive or negative ... the larger a number is the more inset a rim will be and vise versa.
and to answer the topic question... you need to give us the lug pattern... our tC's call for a 5 x 100 ... in other words there are 5 bolts and they are 100 mm apart. if youre bolt pattern is a 5 x 100 then they will fit on your car.... once they are mounted (if you get it done in a repectable place) they will turn the wheel all the way right and all the way left just to make sure it wont rub... which it shouldnt.
Wouldn't a +48 Offset be more tucked than a stock +45 Offset?
(Correct me if I'm wrong.) I have 5Zigens and they are a +35 Offset, and are almost flush all around. The fronts look fine, but the rears are still slightly tucked even with a +35 Offset. My 5Zigens are 18x7.5 and I'm on TRD Springs and I have no rubbing whatsoever.
