will these wheels fit my tc
im planning on getting the drag dr11 glossy black rims
http://www.eracingzone.com/dr11.html
its 17/7/40 with either 4x100 bolt pattern or 5x100 bolt pattern...i also plan to get tein h-tech with the rs1 front lip so would that cause my car to have rubbing or be too low(scratching the lip)?
1.) As for fittment on H-tech you should be fine based on the fact that is it a 17 in rim. 2.) Based on rubbing you should also be fine.
Compaird to stock you will"
Have 5 mm less inner clearnce (fine)
Have 5 mm extended outter lip. (fine)
And as for the RS1 kit, it is stated and advertises that it does not lower bodylines. Now this may not be entirely true, so I would still be cautious about inclines and such but I think that you will be ok.
Hope this helps!
Hope this helps!
scionlife
371
Jun 2, 2015 11:00 PM
carid
Jan 22, 2015 12:49 PM
kingofthecrate
Jan 21, 2015 09:28 PM
2fixA
10
Oct 13, 2003 05:57 AM
