Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
2014 Scion tC Headlight Alignment Help?
Old Jun 23, 2014 | 11:57 PM
suburbansunsets's Avatar
Default 2014 Scion tC Headlight Alignment Help?
I recently purchased my 2014 Scion tC and have been doing mostly light modifications to the vehicle. I put an HID kit inside my car but seem to have trouble with aligning them properly. Is there a up/down, left/right alignment screw? Could the bulbs not fitting properly cause the beams to be spotty and slanted? Can any one post photographs of where to find both sets of alignment screws (bolts) if there are two bolts? Also the actual size of the bolt is 5/16mm someone previously mentioned it was a 10mm but it was to large someone else told me. Please post photos and tips so I can properly align them and optimize safety. Thank you!
Old Jun 25, 2014 | 05:41 PM
Pedro13's Avatar
Hey Suburban, hope this helps... Sorry for the quality, but was the best that I can do on .pdf...
File Type: pdf
Old Jun 25, 2014 | 05:53 PM
Thank you very much do you or anyone else have a guide for the measurements for my lights? How far each light is from the middle the vertical measurements? I need help as much help as possible my alignment isn't perfect at all.
Old Jun 25, 2014 | 07:27 PM
Pedro13's Avatar
Starting with this points, follow the attached. (again, apologize for the .pdf quality...)
Place the vehicle in a location that is dark enough to clearly observe the cutoff line. The cutoff line is a distinct line, below which light from the headlights can be observed and above which it cannot.
Place the vehicle at a 90° angle to the wall.
Cover the headlight or disconnect the connector of the headlight on the opposite side to prevent light from the headlight that is not being inspected from affecting the headlight aiming inspection.
NOTICE:
Do not keep the headlight covered for more than 3 minutes. The headlight lens is made of synthetic resin, which may melt or be damaged due to excessive heat.
File Type: pdf
kleecker
Jan 2, 2015 08:09 PM
minter66
Dec 15, 2014 01:45 PM
LeChuck
Dec 9, 2014 02:26 AM
ScionDP
Dec 3, 2014 02:05 AM
umnitza
Dec 1, 2014 06:26 PM
