Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Easy DRL installation to pass inspection???
Old May 26, 2013 | 11:29 PM
s2artray's Avatar
Default Easy DRL installation to pass inspection???
Hey TC community!
I recently imported my TC2 to Canada and I am due for an inspection. I will require DRL to pass the inspection but I don't want to keep DRL on my TC. Is there a way to easily install DRL and then remove it after inspection???
Thank you!
Old May 27, 2013 | 12:13 AM
noisy1's Avatar
Default Day time running lights
Toyota Canada can turn it on for you but you will get stopped in time for not having them on!
Old May 27, 2013 | 02:20 AM
s2artray's Avatar
So I just go to any Toyota dealership in Canada and they can do it for me?
Old May 27, 2013 | 04:07 PM
s2artray's Avatar
Anyone has different ideas?
I really don't want to pay too much for something I plan on removing, any garage could install DRL for me? From what I've read it is not easy to switch on DRL on Toyotas..., I'd have to buy some equipment and have it installed..., I just don't want to mess too much with the wiring...
Old May 27, 2013 | 05:05 PM
s2artray's Avatar
I just called Toyota Canada and they said that they won't modify an American car. They won't turn on my DRL... They told me to contact a third party to modify my car...
Old May 27, 2013 | 07:30 PM
x_Batman_x's Avatar
Where in Canada are you located?
Old May 27, 2013 | 07:33 PM
s2artray's Avatar
Montreal Quebec
http://www.canadiantire.ca/AST/brows....jsp?locale=en
I'm thinking of getting that cause any mechanic will charge me 200$ for something I don't want.
Is it pretty simple to install?
Old May 29, 2013 | 09:30 PM
x_Batman_x's Avatar
Ah I see. I'm in Detroit, if you were around Windsor I was gonna say drive over and I'll help you out.
The best/cleanest way to do this imo, is to use a set of relays, resistors and fuse taps to run the high beams at a partial voltage, whenever the car is on but switch off when low beans are turned on (normal full voltage high beam operation would not be affected). On some cars this is actually how things work from the factory.
Not familiar at all with that unit, might be really easy. My concern is that the light pattern/brightness requirements for DRLs is technically different than what low beams provide.... Not sure how strictly Canada inspects but if that module simply turns the low beans on at all times (something that can actually be wired easily without using some random module) you still might to pass
Old May 30, 2013 | 03:54 AM
s2artray's Avatar
Thanks for the offer, but it is kinda far from here!
I'll go do my inspection without doing anything probably tomorrow and hopefully the'll let me pass. If not, I'll pass by a mechanic and ask him for the best way to do it for my situation.
Thank you for the support!
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
B_Real45
Feb 23, 2015 07:33 PM
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
