Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Fog Lights Problem
Old Oct 9, 2011 | 07:45 PM
Gapoy's Avatar
Default Fog Lights Problem
Can someone explain me this? Some people say, the color will change after 5 minutes or so... but it didn't change at all...
Old Oct 9, 2011 | 08:05 PM
ROCKLANDTOYOTA's Avatar
IS it supposed to be 3k yellow?
Old Oct 9, 2011 | 08:07 PM
usafscion's Avatar
usually this is caused by the bulb. swap the bulbs to make sure that its not the ballast.
just an idea.. gl
Old Oct 9, 2011 | 09:40 PM
azmadzboy's Avatar
fuse problem, replace it with higher fuse amp and will fix the problem.
Old Oct 9, 2011 | 10:01 PM
SquallLHeart's Avatar
uhh.. no.
Old Oct 10, 2011 | 03:20 AM
MyEvilMonkeys's Avatar
Start up will always be a green color. I had the same issue. Swap bulbs to confirm the issue is bulbs not ballasts. Wipe the bulbs with am achohol swab. Oils will cause color change and possibly burn out faster. Double check the fog alignment. Alignment can cause them to appear a slightly off color at angles. And those that don't know, 3,000 k do not seem as intense yellow as they do in other fog housings. The VRD fogs I had on my 08' were very intense.
Old Oct 10, 2011 | 03:37 AM
Druidiron's Avatar
Um no......... X2 to that^^
Old Oct 10, 2011 | 04:38 AM
Gapoy's Avatar
Thanks a lot guys i will try that...
SkillFreeJake
Jul 27, 2015 12:34 AM
nastytc
Jan 27, 2015 03:50 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
