Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Front turn signal led
Old May 9, 2014 | 02:11 AM
bktply's Avatar
Default Front turn signal led
I have a 2014 Scion Tc. The front turn signal is 1156. I swapped my front turn signals to leds and they will not blink. Anyone have any ideas? Do I need a load resistor?
Old May 9, 2014 | 03:29 AM
KILLER's Avatar
Make sure you are using the correct bulb with the correct base.
Here is a picture showing the differnces
Old May 9, 2014 | 03:35 AM
bktply's Avatar
I am using the BA15S
Old May 9, 2014 | 04:48 AM
Red2014tC's Avatar
USA or Canada> In the US you have to add a load resistor to each side, or change the flasher relay. In Canada you can only add resistors as the Relay is different than the US one.
Old May 9, 2014 | 04:52 AM
bktply's Avatar
I changed the flasher relay and they still wont blink.
Old May 14, 2014 | 07:51 AM
bktply's Avatar
What should I do?
Old May 14, 2014 | 10:06 AM
KILLER's Avatar
Best thing would be to compare both bulbs side to side and make sure the base is identical.
Another thing could be that the bottom base of the bulbs is not making full contact with the contact points in the socket.
Old May 14, 2014 | 10:31 AM
bktply's Avatar
The base is identical.
Old May 15, 2014 | 06:41 AM
Red2014tC's Avatar
What was the part number if the relay you used. Not all are made to work with led bulbs. The ones that work best have a fixed flash interval reguardless of load. I gave up on mine for now because of the amound of work I'd have to do to make it work the way I want it to. But mine is Canadian with a stupid complicated relay.
Old May 15, 2014 | 07:01 AM
bktply's Avatar
I have this relay. http://www.ebay.com/itm/8-Pin-LED-Fl...0d9515&vxp=mtr
Old May 15, 2014 | 09:52 PM
bktply's Avatar
All my turn signals are not working even the hazards. I checked the fuses and they are good.
Old May 16, 2014 | 07:58 AM
Red2014tC's Avatar
Try using that relay with the stock bulbs and see if that works, just to rule out the relay as the issue.
Old May 16, 2014 | 10:35 AM
bktply's Avatar
Even with the stock bulbs don't work. I even tried with the factory relay. This is odd.
Old May 16, 2014 | 07:45 PM
bktply's Avatar
I even have hids and noticed that left side will not turn on at times. I have a relay harness for the hids.
Old May 17, 2014 | 03:28 AM
Red2014tC's Avatar
Might want someone to look at this, hard to diagnose everything on here. Even more so if the stock bulbs and relay no longer work, I'd have another look at the fuses though.
Old May 17, 2014 | 10:03 PM
bktply's Avatar
I checked the fuses. What could be the problem. I have led running rights.
Old Jun 10, 2014 | 04:47 AM
bktply's Avatar
I still can't get the leds to work? How can I switch the polarity on the bulb socket?
Old Jun 10, 2014 | 06:13 PM
Xversa's Avatar
The only way to switch polarity on an 1156 socket is to cut the wires and reconnect the opposite way. DON'T DO IT! Put everything back to factory condition, and have your car checked out by a pro.
Load resistor will not fix your problem, they only correct the blinker speed.
Old Jun 10, 2014 | 11:29 PM
bktply's Avatar
I even tried a 1157 bulb and nothing. I have a flasher rely for the led. I have leds in the rear and they work just fine.
Old Jun 11, 2014 | 12:43 AM
Xversa's Avatar
Does your OEM flasher look like this blue one?
http://tinypic.com/r/hu3a1k/8
Your 2014 may not be compatible what the 2011-2013 flasher. Compare the pins on both units. There may be a difference. BTW are you in Canada? DRL's operate differently then US models. Best advice I can give is to have the system checked.
