Help with 'ABS' light and 'Slip indicator' lights..
Recently my clutch started slipping so I ordered a clutch kit and had a mechanic do the replacement, and now my car drives fine, but the 'ABS' light and 'Slip indicator' lights are both turned on, and I don't know what to do.
Mechanic doesn't know what it is either. I couldn't find anything in the manual, but I probably wasn't looking right. Obviously I want to hold the mechanic accountable to fix it but he can't do anything if he doesn't know. Edit: Scion tC2 2012 6-Speed *Moved to Correct Forum by Administrator Sticky Where to Post Your Question ______________________________ |
Dropping or reinstalling the gearbox may have damaged the front left speed sensor, cable and or connector(s). Ask your mechanic to inspect for visible damage. If by "manual" you mean the repair manual, check the "brake control" section for voltage info and "suspension" section for mechanical info.
