Help with 'ABS' light and 'Slip indicator' lights..
Old Jun 23, 2019 | 02:34 PM
Luitc's Avatar
Default Help with 'ABS' light and 'Slip indicator' lights..
Recently my clutch started slipping so I ordered a clutch kit and had a mechanic do the replacement, and now my car drives fine, but the 'ABS' light and 'Slip indicator' lights are both turned on, and I don't know what to do.
Mechanic doesn't know what it is either. I couldn't find anything in the manual, but I probably wasn't looking right. Obviously I want to hold the mechanic accountable to fix it but he can't do anything if he doesn't know.
Edit: Scion tC2 2012 6-Speed
______________________________
Last edited by MR_LUV; Jun 23, 2019 at 07:34 PM. Reason: Moved to Correct Forum by Administrator
Old Jun 23, 2019 | 03:06 PM
62Fender's Avatar
Dropping or reinstalling the gearbox may have damaged the front left speed sensor, cable and or connector(s). Ask your mechanic to inspect for visible damage. If by "manual" you mean the repair manual, check the "brake control" section for voltage info and "suspension" section for mechanical info.
Gretchen
Scion xD Drivetrain & Power
Nov 8, 2018 05:48 PM
civicjerc
Sep 30, 2010 02:44 AM
Blue_TC_Man
Feb 20, 2009 12:44 AM
gta
Oct 20, 2007 03:45 AM
preciousgem
Aug 4, 2005 01:30 PM
