HO Alternator question
Old Jan 14, 2015 | 12:11 AM
oblivionlord's Avatar
Default HO Alternator question
Has anyone found a company that sells a HO alternator for this gen scion? Also if anyone here has bought one then have you also replaced the pulley as well?
Thanks
Old Jan 19, 2015 | 04:59 AM
Anybody?
Old Jan 22, 2015 | 04:01 PM
CornerHugger's Avatar
http://www.qualitypowerauto.com/item_439/Scion-TC.htm
Try google next time bud. I didn't replace the pulley, as these HO alts come with pulleys preinstalled. The quality power alt's pulley is smaller than the toyota alt's pulley so what you have to do is replace the serp belt with a smaller one. I can't recall what the exact length of the new belt was but if you have a napa near you have them give you a 060486. That's the part number to the belt that i found to work. I ordered the 240 amp alt and I'm happy with it. I've got a 3000 watt sound system and i get no headlight dimming even with my stereo at full tilt. Be sure to do the big 3 if you haven't already. Let me know if you got any questions. Good luck man
Old Jan 23, 2015 | 05:32 PM
What battery are you using btw? Also it appears that the HO alt you linked is one i previously found before but it seems to be the only one on the market.
Old Jan 23, 2015 | 05:33 PM
Stock for now
Old Jan 25, 2015 | 05:36 AM
Im guessing you used a spacer on the negative terminal?
Old Jan 25, 2015 | 05:47 AM
Im not sure what you mean by a "spacer". I am using different battery terminals though
Old Jan 28, 2015 | 05:27 PM
What is your negative terminal? I've used NVX and Kicker.. both don't fit securly around the negative terminal therefore I have to use a spacer ontop of it which I then push the connector ontop of the terminal to form a snug fit.
This is all of course using the stock battery just like you have.
Old Jan 28, 2015 | 08:06 PM
http://www.amazon.com/gp/aw/d/B004LR5K30/ref=mp_s_a_1_1?qid=1422479041&sr=8-1&dpPl=1&dpID=41z2isq9I-L&ref=plSrch&pi=AC_SX200_QL40
Here's what I'm running now
Old Mar 14, 2015 | 07:26 AM
Is there a how to for taking off the serpentine belt for 2nd gen?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
xBassist
9
Jan 21, 2004 07:34 PM
