Sprint Booster, Got Go!
I installed the Sprint booster I ordered today and what a difference. Although the unit does not give you any extra power the throttle response is insane and the car really takes off.
Installation was a snap and it comes with an optional remote that allows you to select between the off, moderate (green light) and race (red light) modes. In race mode the car launches every time you touch the gas pedal!
I was amazed how much difference this little gadget made. I'd recommend green for daily driving and and red for the weekends...
They do work really well. I've been contemplating it. Whats the part number you used?
Links?
Sprint Booster does differ from all of the other throttle modification on the market right now. What makes our product stand apart is that its based on advanced circuity that constantly analyses your pedal inputs and provides the ECU with a signal more in line with what you are demanding. We know because we have spent years developing this product and hold the patent on the technology. We also allow the custom to choose from two modes throttle modes, and OFF (stock). The driver can quickly find their comfort zone between two modes. Should you have any questions about the technology please feel free to pm us
We are happy you enjoyed our product. Keep us posted on your long term experiences.
These are the part #'s right out of their catalog:
http://www.sprintboosterusa.com/download/catalog.pdf
I got the automatic part # from the dealer.
It looks like the same unit will fit various models from the same manufacturer...check our Subaru right below the Scion listings!
If you're referring to the revs that hold or rise when you let off the gas and dump the clutch to shift gears then yes. The increased throttle response/sensitivity seems to have cured this and makes cruising at 45-50mph in 4th gear much steadier, i.e. without the saw horse back and forth while trying to maintain a steady speed!
Does the Sprint unit stay in green mode when you turn off the car and turn it back on? or does it go back to the off position?
I use it in green mode and it stays in green mode when you turn the car off and then back on. It will stay in whatever mode you choose until you hit the selector button to change it to a different mode.
Some Dealerships are already ordering and installing Sprint Booster. As with any mod, proper installation and operation should not result in any negative effects on the vehicle. Sprint Booster can be disabled as well by using the switch.
