Scion tC 2G Forced Induction Turbo and supercharger applications
Where can I get a Turbo for my Scion tC 2014?
Old Aug 31, 2021 | 12:05 AM
Ackey6407's Avatar
Default Where can I get a Turbo for my Scion tC 2014?
I’m new here.
Where can I get a turbo for my Scion tC 2014?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Aug 31, 2021 at 04:21 AM. Reason: Moved to Correct Forum by Administrator
Old Aug 31, 2021 | 08:22 AM
DannoXYZ's Avatar
Moderator
Moderator
Hmm, that's kinda like asking where can I get oil for my car? There's a huge variety of turbos available and specific selection depends upon your power goals, budget and fabrication/programming abilities. How much cutting & welding can do you do on your own? How much harness-making & EFI programming can you do vs. farming it out to engineering shops?
Here's wide selection of turbos available at MAPerformance.com.
Perhaps start with this one.
Old Sep 1, 2021 | 09:51 PM
Ackey6407's Avatar
I’m not sure which one to buy my car is all stock and I’m going to have a shop install the turbo just need to know everything I will need.
Old Sep 1, 2021 | 10:18 PM
drizzoh's Avatar
In short, not available as kits anymore (new).
If you're going to have a shop do everything anyway, just let them build the kit lol.
Old Sep 2, 2021 | 02:02 AM
DannoXYZ's Avatar
Moderator
Moderator
Yes, you need shop to provide and build everything you need to have turbo on car. Shopping list would look something like this:
- Garrett ball-bearing turbo, sized for output-power you desire, download Garrett catalogue here.
- turbo oil-feed and drain lines
- turbo water-feed and drain lines
- custom exhaust manifold to turbo
- custom exhaust after turbo
- external wastegate if needed (depends upon turbo-size and power-output levels)
- boost-controller
- intercooler & mounting brackets
- BOV or CBV
- custom intercooler charge pipes
- forged turbo pistons, 9.0-9.5:1
- forged connecting-rods
- stiffer valve springs
- larger lighter back-cut valves if needed (required for higher power-output levels)
- copper-beryllium fully-radiused valve seats (required for larger valves & higher power)
- head port & polish, factory head could use LOTS of work
- larger injectors and pump
- larger throttle-body
- larger MAF-sensor
- custom intake
- free-flow air-filter
- aftermarket programmable EFI system from Accel DFI, AEM EMS, Apexi PowerFC, Austronic, Autotronic, Electromotive TEC, EMtron, FAST, FiTech, Haltech, Holley, LinkECU, Megasquirt/Microsquirt, MoTeC, ProEFI, SDS-EFI, Wolfe 3D, etc.
- dyno tuning to tie it all together
Lots of cutting, welding, wiring, programming and dyno-tuning. Cost of parts is really just about 10-25% of total depending upon how much cutting, welding, wiring, programming and tuning you can do yourself. Yes, I've done this to many cars and bikes.
turboscion2014
Mar 10, 2016 09:47 PM
ScionDP
Jun 24, 2014 12:25 AM
iwaz
Jun 20, 2014 07:14 PM
anderoo16
Dec 26, 2013 08:05 PM
sukhdeep122
Mar 28, 2013 11:42 PM
