****DELETE ME****
the a/c you have to remove the radio bezel and the piece that hold the cig lighter and then pull the a/c unit out i dont remember if there is a bolt idts but im not sure
as for the speedometer 1. remove the radio bezel 2. remove the mirror controll switch bezel 3. i find it easier to lower the steering wheel all the way 4. pull the gauge cluster bezel straight out 5. on the back you will see little tabs use a small flat head screw driver pop each of them and remove the silver pieces |
and the vent trim is a pain in the ___ so if you start this please realize that it is time consuming and very difficult to do heres a link to how to do it im trying to find time to redo this with pictures
https://www.scionlife.com/forums/sho...d.php?t=211086 |
DIY is going great. Do you know if the orange plastic pieces can be removed from the A/C control gauges? I'm looking at them and it looks like they must have heated the plastic and pushed them in
