Domelight wiring
"8 Pin Connector"
See the small connector below the connector you've labelled 1? That is the connector you want. You want the top/middle pin in that connector. Wire should be blue.
Best ground in the area is inside the drivers kick panel. Remove the drivers door scuff plate and then remove the kick panel. You will see a 10mm bolt looking straight at you with several vehicle grounds on it. Disconnect your negative battery cable before disconnecting/connecting that ground.
Any more questions just ask
"8 Pin Connector"
"8 Pin Connector"
Let me have a look for the wire to go after the switch
I was able to get it.... I ended up just running my wires straight to the domelight and tapping into the blue and black wire there.
domincnTC
08-04-2015 01:47 PM
Wrencher
07-29-2015 01:38 PM
semlin
07-29-2015 02:07 AM
