Scion tC 2G ICE & Interior In-car entertainment and electronics...
Ok guys, match an amp for this speaker! GO!
Old Aug 16, 2013 | 07:52 PM
Gdiddy13's Avatar
Default Ok guys, match an amp for this speaker! GO!
I'm planning on putting this speaker between the front and rear seats, and I need an amp that will fit under the passenger seat.
I'm going for quality over volume here.
aaaaaannnnddd GO!
http://www.sonicelectronix.com/item_...=scsho3799041&
Old Aug 16, 2013 | 08:42 PM
Erager09's Avatar
Do they have dual 4 ohm versions? Dual 2 gives you 1 ohm and 4 ohm wiring possibilities with a mono-block amp. I guess you could do a 2 channel but I'd rather do a mono if it were me.
http://www.alpine-usa.com/product/view/mrv-m250
150w x1 @4ohm. Wire voice coils in series then to amp. 300w max
I personally really like alpine amps so that's where I went first. But dual 4 ohm speaker would be a better design if possible. Most amps are designed to run at 2 ohm
Old Aug 16, 2013 | 09:06 PM
Gdiddy13's Avatar
Well I'm ok with a different sub if it has to be. I'm not the expert by any means. I just know I want an 8" shallow mount that will give me good quality over rattling my ball sack around, and also I'm not looking to spend a ton of cash either. So if you have a better idea for a speaker let me know!
Old Aug 16, 2013 | 09:09 PM
Erager09's Avatar
No no kicker is decent. Don't get me wrong. Just dual 4 ohm would be a little easier to wire usually to a mono block amp. 4 ohm wired in parallel gives you 2ohm going to the amp. That's where most amps are happy. The amp I linked would work well for you. Dunno how that fits into your budget
Now that I think about it, your speaker and a mono-block amp at 4ohm would have less distortion if your going for quality not volume. 4 ohm won't pull as much power from amp but its a small 8in do your not looking to set off car alarms. 2ohm tends to have a higher THD or total harmonic distortion(I think that's it) than the same amp at 4 ohm. Basically the music coming out of the amp is more accurate to the original unamplified sound when running at 4ohm than 2ohm but I dunno if that is really noticeable to the human ear.
Old Aug 16, 2013 | 09:15 PM
Gdiddy13's Avatar
Ok, well if you know of a good 4-ohm I'm all for it. I'm pretty open to ideas but just thought I would start with the basics of 8" and shallow but quality. Thanks again!
Also I just realized that particular speaker is a 6-3/4" speaker. WRONG! I meant this
http://www.crutchfield.com/p_2064CWR...-40CWRT81.html
Old Aug 17, 2013 | 04:52 AM
Erager09's Avatar
That one will work perfect. That speaker in parallel will put 2 ohm to the amp
I can look to see what kicker offers to make everything match brands if you'd prefer that.
Old Aug 17, 2013 | 12:26 PM
Gdiddy13's Avatar
Sure, I don't really have a preference but sometimes it's good to stick with all one brand. Let me know whatcha got.
And now I'm thinking possibly this speaker? It's 4-ohm, and personally I like the price. But if the Kicker is that much better than that's what I'll do.
http://www.sonicelectronix.com/item_...TS-SW841D.html
Old Aug 17, 2013 | 03:36 PM
pfdumigan's Avatar
My personal experiences have shown better output and overall life out of kicker. Pioneer speakers are hit or miss from what I have seen.
Old Aug 17, 2013 | 03:42 PM
pfdumigan's Avatar
I run this amplifier at 1 ohm for my 15" memphis c3.
http://www.sonicelectronix.com/item_...FSJlMgodfXsAbw
If you found a dual 2 ohm version of the sub you're looking at, you could wire it to 4 ohms and have this amp push 500 rms to it. Slightly overpowered but considerably better than underpowering it.
EDIT:
http://www.sonicelectronix.com/item_...-40CWRT82.html
Annndddd there's your sub.
Old Aug 21, 2013 | 01:41 PM
Gdiddy13's Avatar
So I'm sure this is getting old at this point. But let's start all over, you guys obviously know more than I know. I like JBL and I found this for a good price.
Amazon.com: JBL GTO804 Reduced Depth 8-Inch Subwoofer: Car Electronics Amazon.com: JBL GTO804 Reduced Depth 8-Inch Subwoofer: Car Electronics
Now let's match an amp for that. Thanks again!
Old Aug 21, 2013 | 03:23 PM
pfdumigan's Avatar
Perfect with the amp I already recommended.
carid
Feb 18, 2015 09:10 AM
cwong1001
Dec 3, 2014 03:30 AM
DjFrOsT
Dec 13, 2003 04:18 AM
DjFrOsT
Nov 6, 2003 04:54 AM
bluxb
Oct 16, 2003 03:58 AM
