Rear garnish rattle, need advice.
My rear garnish thing rattles like crazy even with the smallest amount of bass. I tested this by putting on music and gently pressing on the garnish, this took away the rattle.
I am looking for advice on how to properly remove the garnish without breaking it so that I can put something behind it to stop the plastic vibrating on the metal.
Here is a pic to clarify. This photo is from /u/devanb3. The arrows indicate where the aluminum meets the plastic causing the rattle.
I am looking to take this plate off so I can install something behind it to keep the aluminum and plastic separate from one another. I know alot of panels on the TC just pull right off, but I don't want to make a mistake when it comes to taking off the garnish.
You will have to take the trim panels in the hatch off. Just a matter of gently pulling down on them. There are 4 bolts (or nuts, don't remember) to remove the "garnish" and you may have to disconnect the hatch release button wires/reverse lights.
I took mine off to paint the emblem and it wasn't that difficult. Maybe 5-6 minutes.
It may be worth mentioning that it is difficult to re-open the hatch if you accidently close it after you remove the wires for the hatch release. just keep that in mind. I had to crawl over the back seats and plug it back in while my friend held the panel in place so it didn't fall.
Thank You. I already took off the interior hatch panels during my rattle investigation. I will look for bolts before I go yanking the garnish off!
airmankevin1
Feb 14, 2018 01:23 PM
RY_TC07
Jul 18, 2017 05:18 PM
