Scion tC 2G ICE & Interior In-car entertainment and electronics...
Rear Speaker Replacement
Old Jun 30, 2012 | 01:58 AM
clickclickw00t's Avatar
I ordered the Scosche Sat-6 and they worked to install the 6.5 speakers I had (alpine type r components) into the rear.
Old Jul 1, 2012 | 08:21 PM
Rob2012TC's Avatar
Thanks, I ordered a set of Alpine R 6.5's for the rear of a car that I'm working on and the Scorsche Sat-6 brackets hoping thery would work... Appreciate your letting me know they're good.
Old Jul 1, 2012 | 08:34 PM
Nice! The Type R components I have sound just amazing. I had to turn the head unit to fade more to the front than the rear because they were just way too loud. I'm running them off of an Alpine MRP-F240. The amp produces 60W x 4 Channels or 100W x 2 Channels. It is running in bridge mode sending 100W to each pair of components. In the trunk I have 2 Kicker Comps with an Alpine MRP-500. I'm going about ordering a Sundown SA-12 or an Alpine Type R 12 (can't decide which yet) and I'm gonna just run a single sub. Fronts are stock. Head unit is a Pioneer MVH-P4400BH. If you're looking for a good spot to hide the crossovers, once you get the rear panel off, on the inside of the panel is like a storage bin of some sorts. I threw my crossovers in there. Works perfectly fine and they do not rattle. I mounted my tweeters in the back of the a-pillar about 3 inches down from the triangle. I have pictures of the install I will upload...
Old Jul 1, 2012 | 08:35 PM
My plan is to ultimately get a 3-way system for the front. I think I will run it off the stock amp as it seems to be rock solid so far.
Old Jul 6, 2012 | 01:57 PM
chicagokid's Avatar
Quick question guys... How do I take off the front and rear side panels to get to the speakers?
Also can I just replace the front 6x9s and keep the stock tweeter and 3x5s? Thanks!
Old Jul 10, 2012 | 01:25 PM
Rear side-panel removal is pretty easy. right near the cupholder is a little thing with some "drinks" or something pictured, get a flathead screwdriver and pop that piece open. Then there should be a big screw in there (you will need a wrench or socket to get it out, I believe its 10mm).
AFter you get that out, just pull the panel out from the ends and it should come right off
not too sure about the fronts though.
Old Jul 11, 2012 | 07:39 AM
Rob2012TC's Avatar
I'll confirm the Scosche Sat-6 work with the Alpine R 6.5 coax speakers for the rear. Use the ring that comes with the Alpines, screw it to the adapter, the screw the speakers to the alpine ring and all set. Pretty decent although when I put the rear panels on the car the speakers seemed really close to the interior panel but I don't think it's touching it. I used mdf for my car which I dynomatted and I think I like it better than the Scosche but I will say the Scosche was much EASIER to do, fast and work well.
Old Jul 28, 2012 | 02:24 PM
chicagokid's Avatar
Anyone know if the JBL GTO628 6.5-Inch 2-Way speakers will fit the Scosche Sat-6_at the rear? I'm getting ready to order it.
Thanks guys...
Old Jul 28, 2012 | 04:03 PM
chicagokid's Avatar
Originally Posted by Jericho941
I do have some pictures of the installation in the doors, but I missed a few key shots when I was last working on the system and I don't really want to pull the doors panels off right now. I'll start a new thread when I get all of the pics done later. I don't want to hijack this thread any more than I have to.
I had to fabricate mounts for both the 4" and 8" drivers. I used layers of mdf, copying the mounting points for the factory speakers. For the tweeter I was able to press the aftermarket one into the factory location in the door panel.
Can you let me know how to pull off the front door panels so I can replacement the 6x9s? and tools needed. Thanks so much for any instructions, pics or DIY!!
Old Aug 1, 2012 | 11:31 AM
Rob2012TC's Avatar
SAT6 and SAT69 adapters work well, however be sure to dynamat these things well because if you decide to really crank your system they may rattle.
Old Aug 1, 2012 | 05:22 PM
Errikos's Avatar
Smile
take off silver handle ( just pull )
take off plate behind door handle and lock ( small pry tool will pop it off come from the rear side of it)
take off piece that is at top near dash pops off
once screws removed go around edge of door and pull ( only clips hold it in )
also use search its posted up with full how to
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
torranosaurus
Jan 28, 2015 04:53 AM
linlow
Scion tC 1G ICE & Interior
Dec 14, 2014 12:56 AM
shaefner
12
Oct 8, 2003 01:46 AM
vpkb
Sep 30, 2003 07:48 AM
