Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
2013 Megan lowering springs @ 1year
Old Sep 24, 2014 | 06:31 PM
Chrisofhammond's Avatar
Default 2013 Megan lowering springs @ 1year
Just wanted to update you guys in case anyone is considering Megan lowering springs. I've had them on my car for almost a year and they've settled quite a bit. I'm at 24k miles and I am on stock struts and none are leaking and we have some bad roads down here! It's still tight and the drop is great. They've been on the car for about 15k miles.
Attached Thumbnails 2013 Megan lowering springs @ 1year-10706533_936566456358409_84161337_n.jpg
Old Sep 24, 2014 | 06:41 PM
criminaltc's Avatar
Good review. That will help a lot of people when they search for Megan springs. Wish there were more of these. People just always post their issues instead.
Old Sep 24, 2014 | 06:49 PM
Only thing I have to compare them to were my TRD's before this. These settled lower and are a good bit tighter. Less body roll vs TRD's not to mention cheaper.
Attached Thumbnails 2013 Megan lowering springs @ 1year-10706537_936567219691666_871285933_n.jpg
Old Sep 24, 2014 | 06:54 PM
Here is where I purchased them FYI
Megan Racing Lowering Springs - Race Consulting Agency - PARTS | KNOWLEDGE | PASSION
Old Sep 24, 2014 | 07:05 PM
Here is a video of me driving with the Megan's on several types of roads.
Old Dec 30, 2014 | 10:55 PM
jaspercanda's Avatar
Originally Posted by Chrisofhammond
Legit site? Ill buy them for my tc 15
Old Jan 1, 2015 | 03:28 PM
hampton1100's Avatar
Thanks for posting!
Would you recommend Eibach's alighment kit, and or Megan racing rear upper camber arms?
Eibach Pro Alignment Kit - K-Spec Racing - racing performance & tuning - air intakes, headers, exhaust, brakes, springs, coilovers, suspension
Megan Racing Rear Upper Camber Arms for Scion tC '10+ - Enjuku Racing Parts, LLC
Old Jan 1, 2015 | 11:23 PM
HOODedDutchman's Avatar
Never knew that eibach kit existed. I'd like to see it installed. WAY cheaper than arms from megan.
Old Jan 2, 2015 | 04:07 AM
I'm probably going to at least get the Eibach kit for adjustibility, they are just for the front though. It seems like other than fabricating something for the rear the Megan racing upper control arms are the only option. I'll post back after the mod
Old Jan 2, 2015 | 10:58 PM
You don't need the front ones unless ur totally slammed on coil overs. Lowering the front doesn't change that much camber wise. There's enough play in the stock suspension you can pretty l much 0 it out with any aftermarket spring.
Old Jan 3, 2015 | 05:29 PM
azztinthebox's Avatar
What do you have them set at as far as height wise? How much lower can you go or can you go any lower?
Old Mar 23, 2015 | 04:39 PM
2012TC's Avatar
I had considered the TRD's. I assume you prefer the Magan ones over those since you had them before? What would you estimate your drop at? Does it stay in alignment or is it necessary to purchase a camber kit?
Old Jun 17, 2015 | 07:01 PM
This reply may be too late, sorry. They were a lot firmer than the TRD and had a lot less roll. Lower in the back for sure. These were just the springs paired with OEM struts. I didn't have a camber kit.
killahXB2
Mar 27, 2015 10:45 AM
ScionDP
Mar 1, 2015 10:57 PM
mark13018
Feb 6, 2015 08:57 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
