Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Eibach Pro-alignment kit
Old Apr 15, 2015 | 09:57 PM
carltc14's Avatar
Default Eibach Pro-alignment kit
Eibach Pro-alignment kit for Scion tc Gen 2 up for sale. Purchased for $68.00CAD, asking $50.00CAD+shipping. Dealer installed my springs and didn't need the alignment kit.
Message, or email, or text me at 1-403-554-9705. Thanks!
"Eibach's Pro Alignment kit is specially designed for each vehicle application and will contain varying components. The kit will provide the amount of correction needed to reverse the negative camber, restoring vehicle stability, performance and safety. The camber alignment kit is recommended with all Eibach SportLine, ProLine, Pro-Street, or Multi-Pro series suspension lowering kits.
Key Features:
Precision Alignment Camber Bolt Kit for Maximum Performance
Prevents Uneven Tire Wear
Wider Range of Camber Adjustment-Suitable for Street or Track Tuning"
Attached Thumbnails Eibach Pro-alignment kit-11010522_10153744335638776_2548324040744381591_n.jpg
Old Apr 21, 2015 | 09:49 PM
ScionDP's Avatar
Damn buddy you should have come to the forum before purchasing. what springs did you get? how are your rear specs in regards to camber?
Old Apr 21, 2015 | 10:51 PM
carltc14's Avatar
I didn't get an alignment on the day of the install, but I went back 2 and a half weeks after install for an alignment and the specs are as the picture says. Apparently the rear camber on the right side is always off according to my technician and not adjustable... So if they were to install the alignment bolts they would have had a worse degree of camber on the fronts.
When I ordered the spring from tDot performance they said it was always recommended to get the alignment kit. But I guess for my situation it's not.
Also, says its a 2012 tc, but I have a 14.
Bama
Mar 29, 2015 04:47 PM
ScionDP
Mar 1, 2015 10:57 PM
Inazuma
14
Jan 8, 2004 01:36 AM
ToyTuners
Nov 4, 2003 07:17 AM
2fixA
Oct 6, 2003 05:01 PM
