Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Left lower control arm removal.
Old 12-29-2017, 04:10 PM
danielt021's Avatar
Default Left lower control arm removal.
Has anyone removed a driver's side lower control arm. Mine need to be replaced because it's cracked (I hit the curb when turning on snowy road).
My concern is there is one long screw and I'm afraid that the oil pan is in the way and won't be able to remove the bolt. Am I right or will I be able to wiggle it out somehow?
danielt021 is offline
Old 02-19-2018, 10:33 PM
gdags's Avatar
Have you been able to replace the left side control arm? I want to do the same but the transmission pan is in the way of the bolt, seems like a real pickle - even if I can wiggle the bolt out can the bolt go back in?
gdags is offline
Old 03-02-2018, 03:06 AM
eatcrispycreme2's Avatar
Am having these same issues. trying to remove passenger side control arm and the oil pan is in the freaking way
eatcrispycreme2 is offline
Old 03-02-2018, 03:29 PM
Ok, ended up just jacking the engine up slightly and bolt cleared just fine for anyone that runs into this
Old 03-02-2018, 03:45 PM
gdags's Avatar
Did you have to loosen an engine mount?
gdags is offline
Old 03-02-2018, 08:05 PM
No, perhaps mine are slightly worn, I have to mention this is on a Scion xB (didn't realize I was in the wrong thread after a Google search) but it shouldn't matter. Gaining half an inch of clearance was all I needed.
Old 03-02-2018, 08:53 PM
gdags's Avatar
Thanks, that helps a lot! I didn't want to have to mess with the engine mounts. I'm also working on an xB.
gdags is offline
10gxiong
02-21-2015 12:53 PM
spooled50trim
11-22-2012 02:01 AM
SDcamoXB
03-14-2009 11:44 PM
Ryz0n
21
10-15-2006 03:59 AM
sciontc_mich
05-14-2006 05:10 AM
Quick Reply: Left lower control arm removal.
