TRD front sway bar setting
Installed my sway bars yesterday. The front bar is adjustable. On my 05 tC the rear was adjustable and I just set it to the stiffest setting to eliminate as much understeer as possible. Having the front adjustable is a little different. I currently put it in the center setting. Any input on people that have the sway bars. Does one setting drive better than the others?
Logically, it seems as though I should put the endlinks in the endmost hole to eliminate as much understeer as possible. Does anyone out there have any input?
The middle will reduce the under-steer a little and will match the reduced body roll to your new rear sway-bar. If you set to aft setting (the stiffest), you unperceivably reduce the body roll, but increase the under-steer. If you find that the car still under-steers, move it to the forward most point. You will not notice the increase in body roll, but the car should over-steer by then.
kleecker
Jan 9, 2015 02:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
