Got these new wheels.
The wheels are 18x8 with a +40 offset on stock yokohama tires.
Ok so I know, its obvious the car needs to be lowered asap. I am doing that next but I am looking into spacers because the spindle comes out about half inch restricting the center caps from clipping into place. It also looks awful with the wheels tucked in. What size spacers do I buy to get a nice agressive stance. Im buying TRD red springs btw.
TRD springs will cover the gap tho, I just want a mild drop. I am also looking for the right height and make the rear wheels stick out a bit more than the front. I will keep searching on what size spacer will work best.
I'm just saying, with those springs, there is no need to worry about anything. You won't rub. You don't need to search for what spacers you need, you just have to look at your car. Spacers usually come 5mm at a pop, so just measusre out how far you want the back to poke out so you can get that staggered look like you were saying.
15mm spacers all around is what I am going with with some Eibach Sportline springs.
H&R spacers with the extended studs. I think those type of Spacers are safer than the adapter type that screw on and go over the hub.
Thanks a million Biglilsteve for the help. you saved me from buying cheap Ebay spacers.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Jayrdee
Oct 15, 2015 03:38 PM
