So, it fits...
Tested out the rear F-Sport wheel of an IS250/350 with 255/35R19 on it. Fits like a glove, just as I thought it would.
There is actually a ton more space for wider, but anyone looking for an OEM type wheel and a good wide, forged wheel, these should be highly considered! You'll need new front center caps though, or remove them as the half shafts stick out too much...but really, thats it.
Oh ya, and even though the picture is only of the rear wheel on the rear of the car, it does fit the front and does the lock-to-lock without issue! You'd want the 19x9's all around.
Probably could, but it wouldn't be forged. These are about $500+ USD each. Considering Volks and other inflated cost wheels are almost a grand a wheel, thats not bad for a wheel that weights only 21lbs for a 19x9.
I'm planning 9.5" wide now myself with a 255/40R18 all around.
When I saw this thread, it got me thinking...I'm looking to put these on
http://www.lextuners.com/f-sport-ful...-x-9-rear.html
with 245/35ZR19 all around...that way the speedo will still be accurate.
These are the tires I would get
http://www.michelinman.com/tire-sele...2/tire-details
^Good choices. The PS2's are a great tire, but a little costly. The one benefit is they are non-directional, so you can rotate them without taking them off the rims.
The new F-Sport wheels are the same specs as the one I installed. You'll have no issues fitting rears all-around. The 245/35R19 tire works too but you could do 255 if you wanted. The tire on the one I mounted was 255/35R19. Your speedo might be out 0.1%, which isn't enough to even care about.
