Is this wheel real?
I recently bought my first scion, I've been looking for wheels all day and found these but I have no idea what they're called (or if they even exist since this looks animated). Anyways I've found similar ones on a different site, but not as good as these. I was just wondering if anyone could help me out.
http://i50.tinypic.com/333yfyt.jpg Also would 18x7.5 be a good size for this type? P.S. if anyone has any suggestions for wheels feel free, I like the 5-6 spoke wheels mostly. |
enkei rp03
Thank you! Do you know if they bend easily?
Enkei is a good brand name...depending on if you hit a curb or something any wheel will bend, you just have to take care of them.
Originally Posted by Tabs
(Post 4101166)
http://i50.tinypic.com/333yfyt.jpg Also would 18x7.5 be a good size for this type? P.S. if anyone has any suggestions for wheels feel free, I like the 5-6 spoke wheels mostly. 450$/wheel, they should be good quality. :P |
Originally Posted by k0ntr0lledka0s
(Post 4101248)
Same, I'm having a hard time finding them in black..
I want to get 18x7.5 with an offset of 45 with the tire size of 245/45/18 Will that rub while my car is on stock suspension? Also will it rub after I put a 1.2-1.5 drop on? |
(Post 4101325)
I want to get 18x7.5 with an offset of 45 with the tire size of 245/45/18 Will that rub while my car is on stock suspension? Also will it rub after I put a 1.2-1.5 drop on? 18x7.5 is the same size as stock with the stock offset only being +39. In essence the stock would stick out further than the aftermarket you're looking at. I'm running 19x9.5 with a 45 offset and didn't rub at all. But my rims are 2 inches wider than stock... And I'm dropped about 2 inches front and almost 3 in the rear |
(Post 4101178)
Originally Posted by DermalsNmohawks
(Post 4101305)
Aluminum wheels will not bend if you hit a curb, they will simply crack/break or shatter. Steel wheels on the other hand will bend and can be bent back into shape.
Originally Posted by 2tCornot2tC
(Post 4102201)
Where did you get your engineering degree from genius? I'll show you a whole bunch of bent aluminum...in any kind of shape you can imagine...even ones that look like a wheel! I've bent my share of aluminum wheels racing cars.
PS pics or STFU :) |
(Post 4102261)
Aluminum rims tend to break more often than bend, while steel rims are very hard to break/crack and they usually bend.
(Post 4102261)
I never said I think it was ____ty
(Post 4102261)
Aluminum rims tend to break more often than bend,...
Where did you say you got your engineering degree from to be able to make such assessments? |
^you realize they use a different grade of aluminum on air planes right?
I think you should re-read all the posts in this thread and show which post I said I have an engineering degree in. |
(Post 4102784)
I think you should re-read all the posts in this thread and show which post I said I have an engineering degree in. Do you realize that you can buy aluminum wheels that are made of the same material airplanes are made of? All the F-1 teams do. |
...yes I realize that but, most of the aftermarket aluminum wheels out there are ____ and a regular set of steel wheels will be better and way cheaper.
Ps why do you write in bold? |
You did not state that at first...now you are qualifying your earlier statement. Yes, you buy a cheap a$$ Chinese wheel for $10, it will be made of recycled aluminum...you get what you pay for. :loser:
Most aftermarket aluminum rims are cheap ___ Chinese, in case you didn't know. BTW you would do horrible on the price is right. I don't know of any cheap ___ Chinese rims which cost $10 a piece to buy. They probably cost $10 or less to manufacture.
