Wheels and tire fitment xxr 522
Old 09-04-2013, 12:47 AM
Tc13's Avatar
Default Wheels and tire fitment xxr 522
I used the wheel Calculator the circled number is that the rim size those tires can handle? Wheels and tire fitment xxr 522-uploadfromtaptalk1378255544468.jpg
I want to get some xxr 522 but I Kinda want to reuse mq factory tires Can you get xxr 522 with. smaller diameter that a 8.5 tire will fit? The xxr wheels. I looked at were 18 x 9.5 I think will the 245 45 tires fit. in deff a noob with dealing with wheels and Tires
Can I get some input from some one with these wheels has any one had to roll your fenders or remove the inner fender? Input is very much appriciated. Ill post a pic of my current stance
Ok just found xxr 522 in 18×8.5 the tire calculator says 225 45 is 18×8.85 will this tire fit?
Sent from my SCH-I605 using Tapatalk 2
Tc13 is offline
Old 09-04-2013, 12:54 AM
Tc13's Avatar
I basically dnt wanna remove my inner fender or roll them but I woildn mind a lil more camber im just not sure what size
Tc13 is offline
Old 09-04-2013, 11:50 AM
k0ntr0lledka0s's Avatar
whats the offset on them? and are you lowered on anything?
k0ntr0lledka0s is offline
Old 09-04-2013, 02:22 PM
Tc13's Avatar
It says on the xxr website u can specialize from +20 -(+4
I dnt really care.what the offset is aslong as I can fit them under my car with out having to roll fenders
Tc13 is offline
Old 09-04-2013, 02:23 PM
Tc13's Avatar
I have raceland coilovers slammed in the front. Prob half an inch up in the back for better alignment
Tc13 is offline
Old 09-05-2013, 11:48 AM
well offset is very important bro haha but if you wana go that way and you just want that wheel in there then just go 8.5 all around with a high offset like +40 and you will be good!
Old 09-06-2013, 12:28 AM
Tc13's Avatar
Is +40 flush with the outside of the rim? Ao I guess im asking is dead center of the rim 0 and negative numbers like -24 would b towards the rotor and + numbers would be going out ? Just trying to get a grip on this concept. Thanks.
Tc13 is offline
Old 09-06-2013, 11:53 AM
you mean flush with your fender? and no actually its the opposite, the more higher you go the more it is to the rotors so a +40 would be tucked in your fender while a -13 for example would be poking out your fender. 0 doesn't mean your even with the fender...now it gets a lil more complicated when you drop the car cuz thats when you have to figure out how low your making it and then your offset changes from when stock height thats y I was asking if your lowered.....so it just depends what look your going for
Old 09-06-2013, 12:00 PM
Tc13's Avatar
Ok I like the flush look I just dnt wanna have awfull tire wear or have to roll my fender. With aftwrmarket wheels will I need extended wheel studs? And can I use regular acorn style lug nuts?. I dnt have to use the STS LUGS that are oem do I?
Tc13 is offline
Old 09-09-2013, 04:26 AM
CelestialxOne's Avatar
Just saw this post i have two tc2s and they are both on stock tires. one is 225 40 and the other is 225 45. 225 40 is on 522s 18x8.5+30 offset, and the 225 45 is on 527s 18x8.75+20 offset. First one is flush tires would tuck nicely if lowered, second one my wheels poke and the tires will rub as soon as i drop it......i plan on rolling.......wooooo hahahah
hope this helps some.
CelestialxOne is offline
Old 09-09-2013, 04:27 AM
ps dont get the 8.5w +30 they dont look right on this car.....just saying....lol
Old 09-09-2013, 04:30 AM
pss just get gorilla lugs off of amazon acorn style 1.5 and no dont need studs. but hub centric rings are suggested....
Old 09-09-2013, 11:46 AM
Tc13's Avatar
Can u post pics of the wheels on both cars?
Tc13 is offline
Old 09-09-2013, 04:37 PM
soFlush's Avatar
You want flush but don't want to roll your fenders.. why not? You roll your fenders to protect your car and wheels/get clearance. If you weren't lowered then you wouldn't need to worry about rubbing with that 4x4 height. The lower your car is the more natural camber you're going to have. You can correct the front camber w/coilovers/crash bolts but there isn't any adjustable rear upper control arms for the rear so you're stuck with whatever camber it gives.
soFlush is offline
Old 09-09-2013, 06:01 PM
Tc13's Avatar
My car is all the way lowered on the front with racelands and all the way down in the rear only reason I dnt wanna roll fenders is because I heared it will crack ur paint I dnt care to bend the lip thats in side the fender i just dnt wanna ruin my paint.
Tc13 is offline
Old 09-09-2013, 06:40 PM
soFlush's Avatar
That's why you do it the right way the first time. If you heat the area where you're rolling with a heat gun then use a fender roller you won't crack the paint.
soFlush is offline
Old 09-10-2013, 11:54 AM
^^ yup that's how you do it! ;-)
Old 09-10-2013, 12:23 PM
Tc13's Avatar
How much is a fender roller to.purchase one
Tc13 is offline
Old 09-10-2013, 02:33 PM
Tshock's Avatar
Cheaper to find someone who has one you can rent. Purchasing is $200+.
You can kiss your stock tires goodbye if you decide on shrinking the camber. My tc eats up tires and alignments annualy with minimal negative camber.
Tshock is offline
Old 09-11-2013, 11:52 AM
^^ yup I can vouch for that to! I have -3 camber and I have to go through a couple tires annually...but it would be cheaper to find a person that can roll them, usually charge around $40 a fender to roll
Quick Reply: Wheels and tire fitment xxr 522
