oem fog light installation help!!!
i've got everything hooked up but i can't seem to find where the relay goes. instructions are somewhat ambiguous and its a tight fit behind the junction box. it doesnt help that you cant see either. anyone else run into this?
Where exactly does the relay go? I have my lights on, wires, switch and the relay to plug into make them work. It sounds like it plugs into the back of the fuse block under the dash board behind that cover. Is that right? Can you just plug it in or do you need to see back there? Where do you plug it in exactly?
Thanks
Thanks
look on the left side of the fuse block underneath the dash left of the wheel. on the left of the fuse box you will see 3 plugs from top to bottom. it goes on the back in the middle. note the configuration of the wire prongs on the plug from the front and position the fuse as such. reach underneath and behind the fuse block to plug it in. you should be able to see your hand on the left side from the front. just hold onto the fuse and be patient. if you want, you can use a mirror. there is a blue denso fuse plugged into the top (above where you need to plug the fog relay in).
Thanks, got it. Man, my hands are just too big. I had to feel around with my two fingers then do it again with the relay pinched between the two fingers sideways. They work and are wonderful, thanks.
yo i didnt do it but i did assist it took my boy to read the book and install it at night less than 45mins. ive never done fogs so i had him do it for me but from where it looked like it was the left side of it look at the diagram "carefully"
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
carid
Jan 8, 2015 11:33 AM
TheTripleC
Jan 4, 2015 06:46 PM
