A way to run Xa foglights and running lights WITHOUT having
Anyone know of a way (wire jumper in fuse box, etc.) to ensure that Xa fogs run with parking lights only, and NOT with the headlights on?
I have a 2002 Ford Focus XZ3, and have been able, via a simple piece of wire, to rig a "jumper" in my car's relay/fuse box so that my fogs run with the parking lights on, but NOT with the headlights on. Any way this can occur with the Xa's fogs? Thanks!!
I dont know of any "shorcut" jumper wires, and i would strongly recommend not doing that.
Its fairly simple to do, you just need a relay. Refer to my response to the same question on xateam.com here...
http://xateam.com/forums/showthread.php?t=57&page=3
The info pertains to an 06, but you could make it work on any year. I also mention the use of a toggle, but it will also work if you find out what feeds the "hot side" of the switch.
I will try and test a switch monday to give you more info!
Thanks, "bf." I mentioned a sort of "jumper wire" because that is the fix which allows me to run my '02 Focus ZX3 fogs without the headlights being on, just the parking lights. I still am deciding whether to buy the factory fog kit for the Xa. I have installed clear front corners, so I already have been under the front of the car, removed the plastic tray underneath, etc. I've seen the directions for the fog light install elsewhere on this site; looks pretty straightforward. Not crazy about spending over $200 for the lights, though. If they were $50 or so, that would be more palatable. Oh well...our "toys" sometimes are costly!!
How're things in Springfield? Way back "when," I went to A.I.C., so I know the area pretty well.
ehh, its still good 'ol springfield. The feds actually just did a huge sweep down in Mason Square and rounded up a ton of big time players lol.
Anyways, there is a company that sells an almost identical kit for the xA and retains all of the factory wiring for a hellofa lot less. I will look into the price of a kit for you and let you know.
Brandon....yeah, I've already found the Xa-specific clears, from a place I forget, now!! Installed them back in December, they look good. Gets rid of the orange-looking front side markers, nice and clear appearance. But I have heard of the Lexus connection previously. Who knew??!! Turns out a Lexus designer, fired from Scion, secretly desired to provide clears for the Xa!!! Well, maybe not...
Hey Jim,
My connect came up dead. He only currently offers plug n play for the tC (go figure).
...anyways, i remembered this ebay seller a while ago that supposedly sold a really decent plug and play kit and i came up with this:
http://cgi.ebay.com/ebaymotors/04-05...em110102674403
...for this price it cant really hurt to at least try right?
Worst case scenario a lense cracks and you have them warranty you a new one ;)
Best of luck to ya.
Best of luck to ya.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
daniinpitt
04-04-2015 08:07 PM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
