HELP INTAKE PROBLEM!!!
Hi,
I installed an afe cold air intake in my 06 xa and now the intake shakes when it's in park and in drive. I can feel the shaking on the break peddle as well. Why is my xa shaking and what should I do to fix this? Thank u for all the help. Also the xa does not shake when the original air box is on. |
how long have you had it in? It takes a bit for it to adjust itself to the difference in airflow
It's been about two years and its been like that since I installed it, I just recently wondered that the shaking might indicate something is wrong.
Do you think the shaking will mess with the timing and lead to expensive problems? |
if it's been two years and nothing bad has happened, I personally wouldn't worry about it.
Oh ok thank you, I think I might try to clamp it down better soon
1 Attachment(s)
oh, i thought it was recent. if it has been that long, its probably just wiggling around, nothing to worry about. the stock airbox has a lot more mounting points so its more stable then aftermarket intakes.
