2004-2006.5 [NCP61]
Install: A.KARPIAK Shifter Base Bushing Kit
Old Dec 16, 2005 | 11:10 PM
mikochu's Avatar
Default Install: A.KARPIAK Shifter Base Bushing Kit
In this tutorial, I will be showing how to install the A.KARPIAK Shifter Base Bushing Kit in my xA. This tutorial should be useful for xA, xB, and Toyota Echo owners with manual transmissions.
The Kit:
The A.KARPIAK Shifter Base Bushing Kit consists of 4 metal bushings that are handmade on a manual lathe by a Canadian. :D These bushings are designed to replace the stock rubber bushings that are between the shift assembly base and chassis. Using metal bushings will help improve shifts by preventing shift assembly flex, which leads to more precise shifting. The TRD Quickshift kit already includes metal bushings, but this kit is great for those who have other short shift kits or just want crisper shifts with the stock shifter.
Tools needed:
Socket wrench w/ 6" extension
10mm and 12mm sockets
Philips screwdriver (optional)
Flathead screwdriver (optional)
The Install:
First, take the shift **** off by spinning it counter-clockwise. Place it somewhere safe.
Pop off the rear console cover.
Take the carpet fabric out of the rear cup holder and undo the screw with either a 10mm socket or Philips screwdriver. Place the fabric piece and screw in a safe place.
Pull the boot all the way up to clear the shift rod.
While holding the rear with one hand, pull the front of the console upward.
There are two white fasteners in the front of the console. Make sure they are attached to the console. Place the console in a safe place.
Using a 12mm socket wrench w/ extension, unbolt these 4 bolts and place them in a safe place.
Use a screwdriver to pop out the inner sleeves on the bushings
Once the metal sleeves are out, remove the rubber bushings. I used the finger-peeling method.
Comparison
Once all of the rubber bushings are taken out, insert the A.KARPIAK metal bushings from under the base.
When you're done putting in the metal bushings, line up the base with the designated holes and bolt it back into place. I tightened them to mikochu-spec. But for you sticklers out there, the 4 bolts should be torqued to 9 ft.-lbs.
Once the bolts are tightened, reinstall the console. Wipe the sweat off your forehead and tidy up. Now you can go through the shifts without the flex, YAY!
I've only had them installed for a day, but going through the gears feels so much more robust. Instead of flexing, the shifter feels like it is actually hitting a wall. These bushings are a must!
If you have any questions, please post here, pm, or email me.
Old Dec 17, 2005 | 03:51 PM
jct's Avatar
jct
doesn't the trd quick shift already come with a metal bushings?
Old Dec 17, 2005 | 04:45 PM
cBc's Avatar
cBc
That is what he stated above:
" The TRD Quickshift kit already includes metal bushings, but this kit is great for those who have other short shift kits or just want crisper shifts with the stock shifter."
Old Dec 17, 2005 | 05:07 PM
n7's Avatar
n7
Scionetics
awesome. where do you get the bushings? or can you just get them at any autozone/checker?
Old Dec 17, 2005 | 05:13 PM
mikochu's Avatar
You can contact Andrew Karpiak at karpiaka@hotmail.com. I believe they are $27 USD and $30 CAD with free shipping. He accepts PayPal, but I would e-mail him before you send money. Also, the bushings are made-to-order, so it may take a week to receive from the time of order.
Old Dec 17, 2005 | 10:45 PM
Tito_Cruz's Avatar
hmmm...would these bushings fit on the tc shift assembly?
Old Dec 19, 2005 | 11:36 AM
TEASER's Avatar
Default Nice post
Nice post, well done.
Dont supose you have excat specs on the bushings?
Old Dec 19, 2005 | 05:21 PM
karpiak's Avatar
The bushings are made of mild steel, and machined to proper size and spec!!! There isnt much too them they replace the existing bushings and are size for size!!
thanks andrew
Old Dec 19, 2005 | 07:13 PM
mikochu's Avatar
Yeah, just contact Andrew at karpiaka@hotmail.com.
Like I said before, they are made-to-order by a Canadian!
Old Dec 19, 2005 | 07:44 PM
Boxer_Rebellion's Avatar
man that's pretty cool...
Old Dec 19, 2005 | 10:40 PM
karpiak's Avatar
By me!!!
if you want i will send them with canadian snow...freeze upon arrival
Old Dec 20, 2005 | 04:12 PM
TEASER's Avatar
Ok so ill have to get the specs myself..................
Old Dec 20, 2005 | 04:17 PM
mikochu's Avatar
What do you mean "specs?" like dimensions? I don't know if Andrew would want to help you with that...
Old Dec 20, 2005 | 07:10 PM
TEASER's Avatar
LOL, Ill publish them as soon as I can.......>
Good info in any case......>
Old Dec 20, 2005 | 10:24 PM
karpiak's Avatar
i am not going to just post the dimensions that i took the time to figure out...but i know not everyone has a lathe or even the skill to make these!!
if you are looking for dimensions, there are a few considerations when taking the dimensions from the stock rubber parts!
andrew
Old Nov 8, 2007 | 06:15 AM
rhin0sb's Avatar
let me get this straight... so the metal bushings prevent the shift assembly base from moving around at the point of contact with the car chasis? since the shift assembly base is made of plastic, it would still flex a little right? did this make a humongous difference? tiny difference? on a scale of 1-10 what would you say?
Old Nov 8, 2007 | 08:09 AM
Zillon's Avatar
Old Nov 8, 2007 | 10:48 PM
mikochu's Avatar
I make myself laugh sometimes...
Old Nov 8, 2007 | 10:51 PM
Zillon's Avatar
Who doesn't?
Amazing how different things seem after two years, eh?
Old Nov 8, 2007 | 11:21 PM
rhin0sb's Avatar
are the bushings for the xA the same as those for an xB? i assume they are, but a wor d of reassurance would be nice.
i see mostly xA and tc people on this thread
